How to generate internal Baffles with exsisting STL mesh?
Like Tree3Likes
  • 1 Post By keepfit
  • 2 Post By andre.weiner
Old   July 23, 2013, 13:47
Default How to generate internal Baffles with exsisting STL mesh?
David Long
keepfit is on a distinguished road
Hi Foamer,
I want to simulate the flow inside a Cyclone. The geometry is shown below:
Part of the air outlet tube is inside the cyclone, so the internal patch (wall) must be created.
I think there are 2 possible ways to do such job:
1) Import the Tetrahedral Mesh generated by GMSH, and then generated the inner walls of air outlet tube with createBaffles, but I didn't find any tutorials about how to generated curved surface (can not find detailed topoSet or setSet guide).
2) Import the Surface Mesh (STL) and utilize the snappyHexMesh to generate the internal cells. But how does snappyHexMesh snap the internal surface and convert it to patches? It's possible in OF 2.2.0 to do this, but could not find the proper examples.
Any advice will be appreciated.
David Long
vs1 likes this.
keepfit is offline   Reply With Quote
Old   July 23, 2013, 18:50
Andre Weiner
andre.weiner is on a distinguished road
Originally Posted by keepfit View Post
... createBaffles, but I didn't find any tutorials about how to generated curved surface (can not find detailed topoSet or setSet guide).
Have a look at the "propeller"-tutorial.
tutorials/incompressible/pimpleDyMFoam/propeller
But: you wont get a proper baffle if the surface of the cylinder is not included in your tet-mesh (see the tutorial).
I would do like this:
- generate the stl of your cyclon
- generate a second stl of the part of the cylinder, that is inside your cyclone
- in the snappyHexMeshDict-file the cylinder.stl gets the attribute "inside" in the part of the surface refinement
        cylinder
            level       (2 2);
            cellZone    cylinder;
            faceZone   cylinder;
            cellZoneInside  inside;
- in version 2.2.0 and higher it is also posible to create baffles (or in your case maybe boundaries) with snappyHexMesh
            //- Optional specification of what to do with faceZone faces:
            //      internal : keep them as internal faces (default)
            //      baffle   : create baffles from them. This gives more
            //                 freedom in mesh motion
            //      boundary : create free-standing boundary faces (baffles
            //                 but without the shared points)
            //faceType baffle;
Best regards, Andre
vs1 and hogsonik like this.
andre.weiner is offline   Reply With Quote
Old   July 24, 2013, 02:19
David Long
thanks for the tips, Andre.
I will try it today.
createbaffles, internal faces, snappyhesmeshdict
[ICEM] generate mesh from stl file for mechanical APDL rupan ANSYS Meshing & Geometry 1 May 5, 2019 21:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generate multiply bodies and then mesh them one by one hz283 ANSYS Meshing & Geometry 1 March 3, 2013 15:27
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
