OpenFoam beginer
Like Tree4Likes
Old   July 25, 2013, 02:45
Default OpenFoam beginer
monty86 is on a distinguished road
Dear all,
I am Phd student, i want to do CFD model for two phase mixing problem.
I am new to openFom. i went through some tutorials that mentioned in openFoam user guide & also run some cases in OpenFoam. I want your valuable guidance regarding how should i proceed on my problem? Is any literature or demo available for how to start the work? How to define & mention my mixing case in openFoam?
monty86 is offline   Reply With Quote
Old   July 25, 2013, 09:49
Artur's Avatar
Artur
Artur will become famous soon enough
I suggest looking at multiphase tutorials, especially:
- interMixingFoam
- twoLiquidMixingFoam
- interDyMFoam (there are quite a few tutorials in this one)
Also, in incompressible/pimpleDyMFoam/mixerVesselAMI2D. Perhaps the propeller tutorial in the same directory as well, depending on what exactly you'll be doing.
Artur is offline   Reply With Quote
Old   July 30, 2013, 02:21
Elvis
elvis will become famous soon enough
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/
MSc/PhD course in CFD with OpenSource software, 2013
also read the courses of the previous years 2012 back to 2007 http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2012
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007
http://www.openfoamworkshop2013.org/...p?Main=2&sub=1 8th OF workshop with training courses @ day 1
there might be valueable presentations on your topic
once again to a look at the workshops of the previous years it contains training material & valueable presentations as well
http://www.openfoamworkshop2013.org/...p?Main=1&sub=2
If you become quite familare with OpenFOAM and you have applied successfully
you might get the chance to attend OpenFOAM SummerSchool http://www.cfd-online.com/Forums/ope...ol-2011-a.html (just found that link Summer school usually takes place every year)
apple-tree likes this.
elvis is offline   Reply With Quote
Old   August 16, 2013, 03:26
- interMixingFoam
Dear Artur,
As per your suggestion i tried t check the above mention tutorials, but when i am tryinig to run the tutorials by blockMesh command after that following error occured,here i am attaching the error message. i am not able understand what does it mean.
sloshingTank2D# cd $FOAM_RUN/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D
root@PU-LT-~/OpenFOAM/root-2.2.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D# blockMesh
| \\ / O peration | Version: 2.2.0 |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : blockMesh
Date : Aug 16 2013
Time : 09:13:18
Host : "PU-LT-"
PID : 2404
Case : /root/OpenFOAM/root-2.2.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D
nProcs : 1
Create time
--> FOAM FATAL ERROR:
Cannot open mesh description file
"/root/OpenFOAM/root-2.2.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/polyMesh/blockMeshDict"
From function blockMesh
in file blockMeshApp.C at line 137.
FOAM exiting
root@PU-LT-:~/OpenFOAM/root-2.2.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D# ^C
Old   August 16, 2013, 03:40
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
That tutorial case requires an extra step before running blockMesh. Check the accompanying Allrun file.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   August 16, 2013, 03:55
Artur's Avatar
Artur
I think it's useful to learn from the start to read the error logs carefully because they are actually meant to help you understand what is wrong. By looking at this one it stands out that the blockMesh dictionary file is missing.
Just as the previous reply said, you need to run this command first to remedy this, as shown in the Allrun script:
m4 constant/polyMesh/blockMeshDict.m4 > constant/polyMesh/blockMeshDict
which simply creates the dictionary file.
Old   August 16, 2013, 03:59
Thanks alot. i checked that command & now its running
Old   August 16, 2013, 04:01
Thanks Artur.., i was unware ot this command as this command is not mentioned in userguide. In case of any difficulty I will get back to you for your help
Old   August 16, 2013, 05:14
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Check this out:
2013 UNIGE Introductory OpenFOAM course-training:
http://www.dicat.unige.it/guerrero/O...ourse2013.html
As a FOAM learner I got lots of useful tips in there.
Best.
mgdenno and Artur like this.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   August 19, 2013, 00:51
Originally Posted by Mojtaba.a View Post
Check this out:
Best.
Dear sir,
Thanks for your suggestion, but i am not able to view or download these documents. Please can you suggest any alternate route for these documents?
Old   August 19, 2013, 10:23
Mojtaba.a's Avatar
Dear sir,
Are you sure? I just checked the download links and they are ok.
Old   August 19, 2013, 10:55
Artur's Avatar
Artur
Same here, downloaded without any problems using chrome and firefox
Old   August 19, 2013, 23:42
Sorry.. Problem was with my system. Its working now.
Artur likes this.
Old   September 2, 2013, 05:50
Hello sir,
Now i am trying to study single phase fluid flow in anchor type agitated vessel as a case to learn more about openFoam. i came to know that i must generate stl file of geometry. can you suggest me how can i proceed & generate ctl file with autocad? i heard about salome but its looking tedious job.
Old   September 2, 2013, 06:57
Mojtaba.a's Avatar
Hello sir,
Well, I think you have got to just export your file with .stl format.
You can use any other CAD programs to do such a thing.
Best
Old   September 2, 2013, 07:04
Best
My problem is that i have only 2D geometry in CAD, I dont know how to develop 3D geometry in AutoCAD. I am also not much aware about other software. can u help out me which software or route will be simple as i am running out of time for my work?
Old   September 2, 2013, 13:29
Mojtaba.a's Avatar
I am not familiar with AutoCAD. There is no need to make it 3D, you just need 2D surfaces in order to get it used with snappyHexMesh.
Right now I am using Solidworks for generating my CAD geometry. Its handy and powerful.
Old   September 2, 2013, 23:39
Thank you sir. I will try this
Old   September 6, 2013, 00:25
Dear sir,
Is there any free soliwork version available? if yes please send me link to donload it..,
Old   September 6, 2013, 01:48
Mojtaba.a's Avatar
Dear sir,
Well unfortunately it is a commercial software and you have to get a license to use it.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 12:08
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 13:14
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Getting OpenFOAM to coexist with an existing JAVA VM nik777 OpenFOAM Installation 5 February 22, 2007 07:21
