Problem going from incompressible to compressible
Old   August 28, 2013, 17:49
Default Problem going from incompressible to compressible
Ben Graves
bgraves is on a distinguished road
Hi everyone,
I am relatively new to OpenFOAM and in the past only ran simulations with the incompressible assumption. Now my research requires me to run without this assumption ie. compressible flow. I ran some simulations using simpleFoam and got good results. I am now trying to run the same simulations with rhoSimpleFoam. The simulation has zero pressure gradient and zero temperature gradient.
The first simulation is just flow over a flat plate at M=0.2 so the compressibility should only have a very small affect. However, when I run the simulations with rhoSimpleFoam I get an error that says "Maximum number of iterations has been exceeded." After looking through different forums I saw that this error is probably due to initial/boundary conditions. Since the simulation ran and produced good results running in incompressible mode, the only files that are different are for temperature, alphaT, and the thermophysicalProperties. I was wondering if anyone could look these over and make sure that I have not made some silly error.
Thanks,
-Ben
My boundary conditions for temperature and alphaT are shown below, as well as the thermophysicalProperties file
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1004.9;
        Hf          0;
    transport
        As          1.4792e-06;
        Ts          116;
Temperature:
internalField   uniform 300;
boundaryField
    front
        type            empty;
    back
        type            empty;
    wall
        type            zeroGradient;
    symm
        type            symmetryPlane;
    top
        type            fixedValue;
        value           $internalField;
    inlet
        type            fixedValue;
    outlet
        type            inletOutlet;
        inletValue      $internalField;
alphaT:
internalField   uniform 0;
boundaryField
    front
        type            empty;
    back
        type            empty;
    wall
        type            alphatWallFunction;
        value           uniform 0;
    symm
        type            symmetryPlane;
    inlet
        type            calculated;
        value           uniform 0;
    top
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
Thanks f
bgraves is offline   Reply With Quote
Old   September 3, 2013, 08:54
Joachim Herb
jherb is on a distinguished road
I think your problem might be related to this: http://www.cfd-online.com/Forums/ope...tml#post425211
What are your U and p/p_rgh boundary conditions?
You could also try the (transient) pimple solver.
jherb is offline   Reply With Quote
tank filling problem with compressible air Cle FLUENT 1 March 8, 2012 23:02
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 08:25
incompressible to compressible cfdgeek Main CFD Forum 9 September 3, 2008 23:54
Convergence problem for compressible flow Saad Main CFD Forum 2 June 5, 2005 15:24
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
