About log and | tee log in OpenFOAM
Like Tree5Likes
  • 2 Post By wyldckat
  • 1 Post By HakikiCanakkaleli
Old   September 7, 2013, 08:57
Default About log and | tee log in OpenFOAM
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Hi Foamers
I have a question about log and | tee log in OpenFOAM.
If I interrupt a run in OpenFOAM for example at t=10sec and then continue it some time later; all the data that was previously been written in the log file (here from t=0 to t=10 sec) will be replaced by this new values (t=10 afterward).
So is it possible to use this | tee log in OpenFOAM to write these new data at the end of the previous log file instead of deleting and replacing the old data?
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
Old   September 7, 2013, 09:30
Retired Super Moderator
Bruno Santos
Greetings Mohsen,
Did you try checking the help provided by the tee command?
tee --help
Or:
man tee
Best regards,
Bruno
cfdonline2mohsen and vivek05 like this.
Old   September 7, 2013, 10:57
Mohsen KiaMansouri
Thanks Bruno for the quick answer.
yeah it was very simple. I think I should turn off my PC and get some sleep!
tee log --help
Usage: tee [OPTION]... [FILE]...
Copy standard input to each FILE, and also to standard output.
  -a, --append              append to the given FILEs, do not overwrite
  -i, --ignore-interrupts   ignore interrupt signals
      --help     display this help and exit
      --version  output version information and exit
If a FILE is -, copy again to standard output.
Report tee bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/coreutils/>
General help using GNU software: <http://www.gnu.org/gethelp/>
For complete documentation, run: info coreutils 'tee invocation'
and
 | tee log -a
worked for me.
Thanks
By the way, How can I exit from the Manual using:
man tee
and go to the next line in the Terminal without closing it?
Old   September 7, 2013, 11:08
Bruno Santos
man tee
It should be written at the end of the terminal:
Manual page tee(1) line 4/49 (END) (press h for help or q to quit)
For more details about man: http://linuxcommand.org/reading_man_pages.php
Old   September 7, 2013, 11:34
Mohsen KiaMansouri
Thanks Bruno
the linuxcommand website is wonderful!
Old   December 14, 2013, 07:39
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
Considering tee is a command that enables output to be written to both standard output and files, some may want to generate separate log files. In that case, I append the files, one to another:
cat log* >> log_all
Iose likes this.
HakikiCanakkaleli is offline   Reply With Quote
Old   March 31, 2020, 16:23
Default error of already run remove log file to re-run
pranay
pranay347 is on a distinguished road
hi i am running a chtRadiation case, initially i run a Allrun file it created log files in the folder but for 2nd time when i run Allrun file after deleting all log files using Allclean file its giving error as "already run on "path" remove log file to re-run". can anyone help me how to proceed?
pranay347 is offline   Reply With Quote
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 21:07
