November 1, 2013, 09:29 |
Define Re Number with rhoCentralFoam
Rep Power: 15 |
Hi guys,
as a beginner, how can I define the Reynoldsnumber for rhoCentralFoam For icoFoam I choosed for Re=10 following parameters: U=(1 0 0) nu = 0.1 D = 1 => Re=20 How can I do this for rhoCentralFoam? Thank you |
November 4, 2013, 04:12 |
Artur
Rep Power: 20 |
Reynold's number is a fundamental flow property and is independent of what solver or code you're using. So the answer would be: you define it in the same way as you did in the example you've posted (I think you have an error there since 1/0.1 = 10, not 20). Still, since you are asking about rhoCentralFoam, which is a compressible solver, you are probably interested in compressibility and so Mach number of your problem will also be important, amongst other things.
Good luck with your case, A |
November 4, 2013, 07:14 |
Rep Power: 15 |
Thanks, got it already. Re=20 was a silly typo of me :-)
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
how to define the number of CPUs | passionfruit | FLUENT | 2 | June 16, 2011 15:53 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
