closed tank and dynamic mesh
Old   December 1, 2013, 13:27
Default closed tank and dynamic mesh
Tobi's Avatar
Tobias Holzmann
I worked with rhoPimpleDyMFoam some times in non closed cases but now I have a closed volumina. Therefor I got "pcorr" step to 1000 iterations every time.
To check if this occure with closed volume cases I changed the tutorial case in the rhoPimpleDyMFoam so that there is no inlet and outlet anymore.
Its the same result. pcorr blows up:
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.0152941 transformation: ((0 0 0) (0.981781 (0 0 0.190014)))
AMI: Creating addressing and weights between 10944 source faces and 10944 target faces
AMI: Patch source weights min/max/average = 0.945398, 1.00512, 0.999941
AMI: Patch target weights min/max/average = 0.951965, 1.00398, 0.999942
GAMG:  Solving for pcorr, Initial residual = 0.999999, Final residual = 20.8413, No Iterations 1000
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
Is there any solution?
Regards
Tobi
PS: @admin - if its possible the title can be changed into "closed volume and dynamic mesh"
Old   December 2, 2013, 06:30
Tobi's Avatar
Tobias Holzmann
I tested my case yesterday again with a few outer faces used to be an atmosphere.
Therefor p is totalPressure and U is an pressureInletOutletVelocity. With this Addition the Simulation is running stable and fast.
pcorr is normal with a few iterations 5 - 20.
But I am still interested why pcorr blows up in closed volume cases.
Maybe I should have a look at the equations
Old   December 8, 2013, 03:25
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Tobias,
It sounds to me, as if the compressibility of the fluid is not taken into consideration by the solver/pcorr loop. You probably changed the total volume of the box, and then pcorr has a problem in putting the excess volume somewhere.
A suggestion for checking this could be as follows:
1. Set up a simple cavity test.
2a. Move the left and right boundaries with the same velocity.
2b. Move the left and right boundaries with different velocities.
Case 2a should be successful, because the total volume remains constant, and 2b should fail.
Good luck,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 6, 2016, 09:11
Ricky-11 is on a distinguished road
Hey Tobi.
I'm also dealing with a closed domain with moving boundaries. Although my model doesn't blow up, the iterations in the pcorr step are always a lot slowing down terribly the simulations.
In your (or others opinion), should a reduced level of convergence for pcorr deteriorate the accuracy of results or can we live with it?
Thanks,
R
Ricky-11 is offline   Reply With Quote
Old   December 10, 2016, 19:38
Tobi's Avatar
Tobias Holzmann
I cannot give you any advice but you can check out - or set - the keyword that calculates the pressure correction for closed volumes. You have to add the keyword in the fvSolution file (not sure, check out the sources yourself).
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Old   December 16, 2016, 15:51
otm
otm is on a distinguished road
Have you set a pRef and pRefpoint somewhere in your domain? I can't see that it should be necessary with a compressible solver though.
Sent from my iPhone using CFD Online Forum mobile app
otm is offline   Reply With Quote
Old   March 27, 2018, 03:26
MichG
MichG is on a distinguished road
Hello Tobias,
I also want to simulate a closed volume stirred tank using the solver rhoPimpleDyMFoam. Im simulating an incompressible fluid, but need the compressible version of the solver for the heat transfer simulation. As you described, the simulation runs only with one patch defined as inletOutlet. My problem is now, because its an inlet, I get a flow in and out of the domain, but I want the domain to be closed.
I defined my BC as follow:
U
    oben
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
p
    oben
        type            totalPressure;
        p0              $internalField;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           $internalField;
Do you know how to define the patch, that I dont get a mass flow in and out of the domain with still getting a stable simulation?
Kind regards
Michael
MichG is offline   Reply With Quote
Dynamic Mesh (Wave Generation in a Tank) mu ke FLUENT 2 September 16, 2015 02:35
Wave tank dynamic mesh Doro FLUENT 0 October 27, 2011 04:39
dynamic mesh Streamboy FLUENT 1 June 21, 2011 17:03
dynamic mesh interDyMFoam parallel run and processor boundaries lukasfischer OpenFOAM Running, Solving & CFD 0 August 12, 2009 06:36
dynamic mesh and udf problem boboroo FLUENT 1 January 20, 2008 21:26
