Heat Flux at boundary inconsistency
Old   March 7, 2020, 02:00
Default Heat Flux at boundary inconsistency
Ashish Magar
ashishmagar600 is on a distinguished road
Hello Everyone..!
I am trying to simulate a shell and tube heat exchanger (STHX) case, wherein I solve for flow and heat using chtMultiRegionSimpleFoam.
I obtained heat flux through each tube wall as around 50000 W/m2.
However, when I tried a case with a single tube with walls and giving 50000 W/m2 as out-flux (meaning negative flux) at the outer solid walls of the tube, I am getting temperatures below 273K. The simulation with the complete geometry of SHTX did run properly and had reasonable temperature values.
This is just a study I am doing to observe the behavior of each tube.
Any suggestions?
ashishmagar600 is offline   Reply With Quote
Old   March 10, 2020, 02:22
Ashish Magar
Just to add to my question, when I give flux in terms of Heat Transfer coefficient and ambient temperature I am getting a solution as expected.
Any reason why this is happening?
Old   March 10, 2020, 04:18
Carlos Rubio Abujas
crubio.abujas is on a distinguished road
Could it be that either of the heat fluxes [W/m2] you mentioned where actually a heat flow [W]? That may explain the radical difference in the behaviour when setting the value and that the differences disapeared when using a heat transfer coefficient.
crubio.abujas is offline   Reply With Quote
Old   March 10, 2020, 05:53
Ashish Magar
I specifically checked that I was not doing this mistake.
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
