March 7, 2020, 02:00 |
Heat Flux at boundary inconsistency
Ashish Magar
Rep Power: 9 |
Hello Everyone..!
I am trying to simulate a shell and tube heat exchanger (STHX) case, wherein I solve for flow and heat using chtMultiRegionSimpleFoam. I obtained heat flux through each tube wall as around 50000 W/m2. However, when I tried a case with a single tube with walls and giving 50000 W/m2 as out-flux (meaning negative flux) at the outer solid walls of the tube, I am getting temperatures below 273K. The simulation with the complete geometry of SHTX did run properly and had reasonable temperature values. This is just a study I am doing to observe the behavior of each tube. Any suggestions? |
March 10, 2020, 02:22 |
Ashish Magar
Rep Power: 9 |
Just to add to my question, when I give flux in terms of Heat Transfer coefficient and ambient temperature I am getting a solution as expected.
Any reason why this is happening? |
March 10, 2020, 04:18 |
Carlos Rubio Abujas
Rep Power: 9 |
Could it be that either of the heat fluxes [W/m2] you mentioned where actually a heat flow [W]? That may explain the radical difference in the behaviour when setting the value and that the differences disapeared when using a heat transfer coefficient.
March 10, 2020, 05:53 |
Ashish Magar
Rep Power: 9 |
I specifically checked that I was not doing this mistake.
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
