Line Average during runtime or after
Old   January 17, 2014, 16:31
Default Line Average during runtime or after
Ram
ramachandran163 is on a distinguished road
Hi all,
I am trying to get the average value of different parameters along a line in an internal flow. The line does not lie on a patch or anything. I am able to read all the values using the sampleDict as below but I would like to get the average value of it. I am pretty confident that this should be straight forward and that I should be able to achieve it through controlDict or sampleDict, but I am just not able to.
My sampleDict file:
setFormat raw;
interpolationScheme cellPoint;
fields
    p
    Ux
    Uy
    Uz
    T
sets
    lineAB
        type        uniform;
        axis        distance;
        start (4.16 6.16 0.0875);
        end (4.16 8.9 3.43);
        nPoints 50;
    lineCD
        type        uniform;
        axis        distance;
        start (4.16 8.9 0.07);
        end (4.16 6.16 3.41);
        nPoints 50;
can I add something to this existing code to get the average or should I use something similar in the controlDict file to get the average. I am looking for the right keywords and as to where to use them in the code.
I did look in the fieldAverage function and some of the operations that can be used to get the averages during runtime but, I am not able to figure out how they can be used with "sets" type of data.
Thank you very much.
Ram
ramachandran163 is offline   Reply With Quote
sampledict, sampling options
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
[Gmsh] GMSH and OpenFOAM derath OpenFOAM Meshing & Mesh Conversion 44 September 4, 2008 05:09
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
