Different fluids, question
Old   March 12, 2014, 12:18
Default Different fluids, question
Lenzo
lenzo is on a distinguished road
I need to simulate a case where air and two more fluids (gas state too) interact cause convection movements. The good point is that these fluids do not react among themselves.
I am a totally beginner in OpenFoam but I have the user manual and I am learning from there and examples and tutorials that I can find on internet.
My question is: Do I need a multiphase solver for my case? Cause I am not sure if multiphase means more fluids or different states of the same fluid (liquid and gas).
So, if it is not multiphase, then which solver would you recomend me? Or which kind of solvers?
And finally, Do you have tutorials for this solver? Or do you know where I can find them?
wating for your answers
Thank you very much,
lenzo is offline   Reply With Quote
Old   March 13, 2014, 11:54
Prosper is on a distinguished road
I believe in your case it is multiphase flow.
I also just started to simulate multiphase flow and I suggest you starting from 'interFoam' (or 'compressibleInterFoam' if it's compressible). You can find those examples in the tutorial folders.
As a starter I found it confusing to read some tutorials because they don't have much comments and explanations. So I think you need to be patient.
Best,
Prosper is offline   Reply With Quote
Old   March 13, 2014, 12:08
Lenzo
Originally Posted by Prosper View Post
Okay thanks.
Yes, I know the tutorial folders...but these tutorials without....a document with explanations like the user manual....it's really hard, even senseless...
Nevermind, the interFoam has the breaking of a dam tutorial explained on the user guide, so I will focus on this one!
Thanks a lot
Old   March 17, 2014, 11:27
Joachim Herb
jherb is on a distinguished road
If you had only two fluids you might be able to use twoLiquidMixingFoam. Have a look at the implementation of the solver and check if you can extend it to use three fluids.
jherb is offline   Reply With Quote
Old   March 24, 2014, 16:55
Jace
zhengzh5 is on a distinguished road
Okay thanks.
Thanks a lot
hey, I think (to the best of my knowledge) that multiphase refers to liquid-gas or multiple liquid scenarios...and since you have mixture of 3 gases, maybe try dieselFoam/sprayFoam and just turn the liquid injection off? Those solvers are capable of solving a system involving multiple gaseous species.
Maybe explain the problem you're trying to simulate in more detail?
Regards,
zhengzh5 is offline   Reply With Quote
question about uds tanven FLUENT 2 July 5, 2015 11:22
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
Undergrad looking for some advice regarding carrer's in fluid's. TossedSalad Main CFD Forum 1 August 16, 2009 19:19
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
Question from a non-Fluid person ozzy Main CFD Forum 6 September 4, 1998 04:09
