(interfoam) shear stress at water air interface !
Old   April 7, 2010, 14:58
Default (interfoam) shear stress at water air interface !
openfoam1 is on a distinguished road
hi guys
I'm using interfoam solver for my 2D multiphase problem (water - air)
My goal on my simulation is to calculate the shear stress on the water-air interface
Because alpha_1 is not a discreet variable (range from 1 for water to 0 for air) so i can't really define the interface
Can any one have experience in this matter tell me how to calculate the shear stress on the interface using some utility in openfoam or even share an effective idea..
thank you very much ..
best regards..
openfoam1 is offline   Reply With Quote
Old   April 7, 2010, 15:03
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I think in gerneral the interface is defined as \alpha_1 = 0.5.
May this be a good asumption in your case?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 7, 2010, 15:48
thank you for your fast reply
yes i know that is very good ,, but do you know a way to automatically calculate shear stress using a utility in openfoam or in paraview
i think if i didn't find any of those ,, the standard way is to calculate the velocity gradient in the cells of alpha1=0.5 ,, then i must get the gradient in the direction of the interface ( because the shear force must be tangent to the interface ),, which is a very complicated issue (i must also know the direction of the interface at every cell )
best regards
Old   April 8, 2010, 13:31
sega's Avatar
Sebastian Gatzka
best regards
Oh, I'm not aware if such a tool exists. I'm afraid you wil have to write it yourself.
But - good for you - the normal vector of the interface (its direction) is already used in interFoam to calculate the force due to surface tension and will point into the direction of the gradient of \alpha_1!
\vec{n}_i^0 = \frac{\nabla \alpha_1}{|\nabla \alpha_1|}
So concider this part solved. The rest should be up to you.
Get back to us!
Old   April 8, 2010, 16:10
Patricio Bohorquez
pbohorquez is on a distinguished road
hi guys
best regards..
It is quite elegant to add a function to the interfaceProperties in order to do so automatically during the numerical simulation. There you could gain access to the interface curvature and to the velocity field.
Application
interfaceProperties
Description
Properties to aid interFoam :
1. Correct the gamma boundary condition for dynamic contact angle.
2. Calculate interface curvature.
3. Calculate the shear stress.
pbohorquez is offline   Reply With Quote
Old   April 10, 2010, 10:46
Get back to us!
Hi sega
do you know how can i get the velocity gradient in the output data of my final time like U , p , and alpha1
thank you
Old   April 10, 2010, 11:28
sega's Avatar
Sebastian Gatzka
Hi sega
thank you
If you have luck, you can create a velocity gradient field with foamCalc.
But from the information at slice 34 I'm not so sure anymore.
Otherwise you will have to do it yourself.
You can create the explicit gradient from the finite volume calculus class:
fvc::grad(U)
Have a look at the Programmers Guide (Page 37)!
Old   April 11, 2010, 02:20
fvc::grad(U)
unfortunately foamCalc only have gradient magnitude magGrad , but i want the gradient itself
if i know that this member functin grad(U) for fvc class is used to get the gradient of the velocity , how can i use it to get the gradient of the last time of the simulation
I'mvery sorry cause I'm quite new to C++ programming
best regards
Old   April 11, 2010, 05:15
sega's Avatar
Sebastian Gatzka
best regards
You will have to loop though all the timesteps which have been written to the folders. So you will be able to get the gradient for each timestep.
I suggest you have a look into the code of the foamCalc function which caluclates magGrad or magU. I suppose it will do the same loop.
Old   January 13, 2014, 11:25
idefix is on a distinguished road
I know this thread is a little bit old but nevertheless I hope someone could help me:
I also want to calculate the interfacial shear stress. Did anyone find a good way to calculate it?
Thanks a lot.
idefix is offline   Reply With Quote
Old   July 16, 2014, 12:31
Nara Shikamaru
shikamaru is on a distinguished road
I am working on the same problem and almost done with the equations to be calculated. I got a lot of help from this post. I will suggest anyone working on this problem reads this post first.
http://www.cfd-online.com/Forums/ope...bend-pipe.html
I understand all the formulations given in that post. I am working with two incompressible immiscible fluids (VOF formulation) with interFoam solver. The only question I have is regarding the stress tensor that should be used for the calculation of traction. Should the viscous stress tensor be used for calculating the Traction vector? This is what I would do if I was doing solids
\tau_{ij}=\mu (\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i})
or, The total stress tensor including the pressure term should be used?
\sigma_{ij}=-p\delta_{ij}+\mu (\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i})
shikamaru is offline   Reply With Quote
Old   October 27, 2014, 03:59
Hello shikamaru,
are you still interested in this topic?
I would use the first equation you wrote in the last post for i is not equal to j.
Did you calculate the shear stress on the wall or at the interface?
See you
idefix
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
Heat Transfer Coeff on the water air interface Anton Main CFD Forum 3 June 2, 2010 01:49
Boiling of water with hot air Dr. Flow Squad CFX 2 July 27, 2009 07:37
Post processing - Wall shear stress Carlo Siemens 1 March 4, 2009 07:35
water and air interface boundary Shivakanth Main CFD Forum 2 September 25, 2008 09:11
