Why ReactingFoam gives different results with different number of processors?
Old   May 18, 2015, 01:59
Default Why ReactingFoam gives different results with different number of processors?
James Behzadi
JBUNSW is on a distinguished road
Dear Foamers,
I have run into a peculiar case and appreciate any help.
case setup: To expose the problem better, I have setup a simple 1D hydrogen case for use with reactingFoam (attached). The resolution is 4 microns with domain length being 1mm with periodic BC. Initially all variables are uniform and only we have a harmonic temperature distribution. To ensure this is not related to chemistry, I have turned the reaction "off".
What is wrong: After only "one" time step the results for "U" field is different if you run the case with 1 or 5 cores (figure attached). Is this expected or I am missing something here?!
Thanks in anticipation,
James
JBUNSW is offline   Reply With Quote
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext miladrakhsha OpenFOAM Community Contributions 106 July 3, 2023 10:26
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
Stable boundaries marcoymarc CFX 33 March 13, 2013 06:39
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
