Second order temporal accuracy with pimpleDyMFoam
Old   December 20, 2015, 23:29
Default Second order temporal accuracy with pimpleDyMFoam
kkpal is on a distinguished road
Dear all,
In the simulation of vortex induced vibration of a flexibly mounted rigid circular cylinder, I modified the case from the wingMotion tutorial and tried to change the ddtScheme from Euler, which is first order accuracy, to backward, which is second order one. The case with Euler went well, however, with backward scheme the computation diverged very quickly!
With a fixed cylinder simulation where there is no mesh deformation, both euler and backward worked well.
Have someone else encountered this problem?
kkpal is offline   Reply With Quote
Old   December 21, 2015, 02:01
I attach my case file here. Hope some one could test it and give me some hints.
https://drive.google.com/open?id=0By...0N6anFZTGNpRDA
Old   December 21, 2015, 13:58
saneku is on a distinguished road
Hi! Did you try to reduce timestep?
saneku is offline   Reply With Quote
Old   December 21, 2015, 19:24
Yes, I tried reducing time step 10 times smaller, the courant number is around 0.2! But the problem is still there.
Old   December 22, 2015, 02:43
have you look here http://cfd.direct/openfoam/user-guide/fvschemes/ ?
section 4.4.6
Old   December 22, 2015, 03:38
section 4.4.6
Dear Saneku!
Among the ddtschemes listed in section 4.4.6, I tested Euler, backward and CrankNicolson.
Euler worked well;
backward diverged;
CrankNicolson with values smaller than 0.4 worked well, with values larger than 0.5 diverged.
Old   July 17, 2016, 08:01
hi, guys.
The reason for the blow up with second order schemes is that i was using a very small mass ratio for my cylinder. It seems that the weak coupling fsi algorithm does not work well for low mass ratio.
As I increase the mass ratio, this problem is resolved.
Best regards,
First Order to Higher Order Blending Factor NormalVector FLUENT 4 November 13, 2023 07:06
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 21:01
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 07:12
check order of accuracy of MUSCL-Hancock scheme legend Main CFD Forum 1 January 31, 2009 14:14
Second order convergance. Rob FLUENT 2 July 20, 2004 10:49
