Second order temporal accuracy with pimpleDyMFoam |
December 20, 2015, 23:29 |
Dear all,
In the simulation of vortex induced vibration of a flexibly mounted rigid circular cylinder, I modified the case from the wingMotion tutorial and tried to change the ddtScheme from Euler, which is first order accuracy, to backward, which is second order one. The case with Euler went well, however, with backward scheme the computation diverged very quickly! With a fixed cylinder simulation where there is no mesh deformation, both euler and backward worked well. Have someone else encountered this problem? |
December 21, 2015, 02:01 |
I attach my case file here. Hope some one could test it and give me some hints.
https://drive.google.com/open?id=0By...0N6anFZTGNpRDA |
December 21, 2015, 13:58 |
Hi! Did you try to reduce timestep?
December 21, 2015, 19:24 |
December 22, 2015, 02:43 |
have you look here http://cfd.direct/openfoam/user-guide/fvschemes/ ?
section 4.4.6 |
December 22, 2015, 03:38 |
#6 | |
Among the ddtschemes listed in section 4.4.6, I tested Euler, backward and CrankNicolson. Euler worked well; backward diverged; CrankNicolson with values smaller than 0.4 worked well, with values larger than 0.5 diverged. |
July 17, 2016, 08:01 |
hi, guys.
The reason for the blow up with second order schemes is that i was using a very small mass ratio for my cylinder. It seems that the weak coupling fsi algorithm does not work well for low mass ratio. As I increase the mass ratio, this problem is resolved. Best regards, |
First Order to Higher Order Blending Factor | NormalVector | FLUENT | 4 | November 13, 2023 07:06 |
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result | gemini | Main CFD Forum | 12 | December 27, 2011 21:01 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 07:12 |
check order of accuracy of MUSCL-Hancock scheme | legend | Main CFD Forum | 1 | January 31, 2009 14:14 |
Second order convergance. | Rob | FLUENT | 2 | July 20, 2004 10:49 |
