[RapidCFD] Discussion thread on how to install and use RapidCFD
Like Tree8Likes
Old   July 26, 2016, 21:30
Default Single thread running is ok, but parallel running still stuck
  #21
Pin Lyu
tripodtwostep is on a distinguished road
Well, I abandoned Quadro 4000 (cc2.0) and found a Tesla K10 (cc 3.0) to test.
Single thread running(gpu) is Ok, about 4x faster than single thread cpu. (Better performance than cudasolver in foam-extend 3.2)
However when I compile openmpi1.8.4 in thirdpary folder and try 'mpirun -np 2 pisoFoam -parallel', error occurs:
| RapidCFD by simFlow (sim-flow.com)                                          |
Build  : dev-9fc614f4e816
Exec   : pisoFoam -parallel
Date   : Jul 27 2016
Time   : 08:44:37
Host   : "asus-Z10PA-D8-Series"
PID    : 16766
Case   : /home/asus/RapidCFD/asus-dev/grid_1000x1000/cavity-rcfd-2
nProcs : 2
Slaves : 1("asus-Z10PA-D8-Series.16767")
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
terminate called after throwing an instance of 'thrust::system::system_error'
  what():  function_attributes(): after cudaFuncGetAttributes: invalid device function
[asus-Z10PA-D8-Series:16767] *** Process received signal ***
[asus-Z10PA-D8-Series:16767] Signal: Aborted (6)
[asus-Z10PA-D8-Series:16767] Signal code:  (-6)
[asus-Z10PA-D8-Series:16767] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0)[0x7ffaa3822cb0]
[asus-Z10PA-D8-Series:16767] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37)[0x7ffaa3822c37]
[asus-Z10PA-D8-Series:16767] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x148)[0x7ffaa3826028]
[asus-Z10PA-D8-Series:16767] [ 3] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(_ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x155)[0x7ffaa412d535]
[asus-Z10PA-D8-Series:16767] [ 4] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x5e6d6)[0x7ffaa412b6d6]
[asus-Z10PA-D8-Series:16767] [ 5] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x5e703)[0x7ffaa412b703]
[asus-Z10PA-D8-Series:16767] [ 6] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x5e922)[0x7ffaa412b922]
[asus-Z10PA-D8-Series:16767] [ 7] pisoFoam(_ZN6thrust6system4cuda6detail5bulk_6detail14throw_on_errorE9cudaErrorPKc+0x55)[0x452995]
[asus-Z10PA-D8-Series:16767] [ 8] /home/asus/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libincompressibleRASModels.so(_ZZN6thrust6system4cuda6detail10for_each_nINS2_3tagENS_10device_ptrIiEEmNS_6detail23device_generate_functorINS7_12fill_functorIiEEEEEET0_RNS2_16execution_policyIT_EESC_T1_T2_EN10workaround13parallel_pathERNSD_IS4_EES6_mSB_+0x5e)[0x7ffabd3e1a9e]
[asus-Z10PA-D8-Series:16767] [ 9] /home/asus/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libOpenFOAM.so(_ZN4Foam7gpuListIiEC1Ei+0x92)[0x7ffaa4e50912]
[asus-Z10PA-D8-Series:16767] [10] /home/asus/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libOpenFOAM.so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE+0x426)[0x7ffaa5025a46]
[asus-Z10PA-D8-Series:16767] [11] /home/asus/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libfiniteVolume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjectE+0x19)[0x7ffaa9769389]
[asus-Z10PA-D8-Series:16767] [12] pisoFoam[0x447d9d]
[asus-Z10PA-D8-Series:16767] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7ffaa380df45]
[asus-Z10PA-D8-Series:16767] [14] pisoFoam[0x449fb5]
[asus-Z10PA-D8-Series:16767] *** End of error message ***
mpirun noticed that process rank 1 with PID 16767 on node asus-Z10PA-D8-Series exited on signal 6 (Aborted).
I set np=2 because K10 has two GK104 GPU inside. And through Nvidia's performance monitoring tool NVVP, I can see only 1 GK104 is running in single thread test.
Do anybody know how to use multi-gpu in a node, or how to use mpi in multi gpu-node?
Originally Posted by mesh-monkey View Post
I get a similar issue - I believe it is related to the cuda compute capability (CC, CUDA_ARCH or sm_xx). RapidCFD by default is designed to run using CC 3.0 - mostly cards with Kepler chips (see listing here). Your Quadro 4000, like my Quadro 6000, has a Fermi chip and is CC 2.0.
There was a previous pull request to adjust the code to make it work, but appears to have been abandoned.
The issue comes down to the difference in how CC 3.0 handles textures objects. The file in question is src/OpenFOAM/containers/Lists/gpuList/textures.H
I have tried unsuccessfully to modify the code to make it work, however I'm well over my head programming-wise.
Any cuda-programming geniuses around that could help?
Thanks, Tom
tripodtwostep is offline   Reply With Quote
Old   August 29, 2016, 12:41
Default Running slow on Titan Black
  #22
Per Jřrgensen
perjorgen is on a distinguished road
I have compiled rapidCFD and are able to run the (modified) tutorials...
But they are 10 times slower on a Titan Black than running single threaded on the CPU :-(
Could I have accidentally set on some debugging or am I missing some configuration of the GPU or maybe I modified the tutorials wrong... I tried pimpleFoam/pitzDaily and icoFoam/cavity
Thanks in advance
Best regards,
Per
perjorgen is offline   Reply With Quote
Old   September 9, 2016, 19:20
Retired Super Moderator
Bruno Santos
Quick answer: When it comes to testing with many cores/streams/threads, you need to think "big". For example, with traditional CPU based computing, the rule of thumb is roughly a minimum of 50000 cells per core/processor/subdomain.
I don't know how much RAM it equates to on a GPU, but the rule of thumb I use for CPUs is that 1 million cells (hexahedral-dominant mesh) requires 500 MB to 1 GB of RAM, depending on the solver and the number of equations.
Therefore, the default cavity and pitzDaily cases have 100 or 1000 cells... that would be like using a shotgun (the Titan) to kill an ant (the small tutorial cases) .
So, with a Titan GPU, you should aim to something fairly bigger than those small tutorial cases.
nnunn likes this.
Old   September 11, 2016, 12:47
LisaMarie is on a distinguished road
I also tried to install RapidCFD in several ways as described here, but always get error massages...
At first I tried to install as told by the github wiki, but I got error messages like: (see also attached file log.make)
UOPwrite.dep:134: recipe for target 'Make/linux64NvccDPOpt/UOPwrite.o' failed
make: *** [Make/linux64NvccDPOpt/UOPwrite.o] Error 1
or
could not open file mpi.h for source file UOPwrite.C due to No such file or directory
When I patched the math_functions.hpp file for CUDA-7.5 as described by aee, my desktop was totally messed up (splitted in half etc)...
Usage:
math_functions.hpp is found in /usr/local/cuda-7.5/targets/x86_64-linux/include/ (default install) or wherever you installed Cuda 7.5.
If in the default location, you will need root or sudo access for the following steps:
1) Place the patch file in the same directory.
2) Copy the original math_functions.hpp to math_functions.hpp.org and/or move it someplace safe.
2) execute
patch < Cuda7.5_math_functions.hpp.patch
I luckily did a system backup before, which I could restore... Afterwards I again looked at the log.make file from the first try and did not find an error message related to the cuda_math_functions, so patching the file would not work for me...
Like aee I tried to set the MPI to SYSTEMOPENMPI (from OPENMPI) as it was set in my OpenFoam installation (v3.0+), but then I get lots of output like: (see also attached file log.make_systemopenmpi)
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file UOPwrite.C
could not open file omp.h for source file UOPwrite.C due to No such file or directory
Can anybody please help me to install RapidCFD?
Some information about my setup:
  • Ubuntu 16.04 Desktop x64;
  • gcc (Ubuntu 5.4.0-6ubuntu1~16.04.2) 5.4.0 20160609
  • CUDA version 7.5
  • Quadro M4000M
  • OpenMPI 1.10.0 in folder /home/openmpi
LisaMarie is offline   Reply With Quote
Old   September 12, 2016, 14:03
I was finally able to kind of compile RapidCFD. (foamInstallationTest failed)
Even though I had two error messages remaining, I could call solvers like icoFoam.
UOPwrite.dep:168: recipe for target 'Make/linux64NvccDPOptSYSTEMOPENMPI/UOPwrite.o' failed
make: *** [Make/linux64NvccDPOptSYSTEMOPENMPI/UOPwrite.o] Error 1
UIPread.dep:168: recipe for target 'Make/linux64NvccDPOptSYSTEMOPENMPI/UIPread.o' failed
make: *** [Make/linux64NvccDPOptSYSTEMOPENMPI/UIPread.o] Error 1
Trying to run a case with ~6 Million cells, the output of simpleFoam stopped after the header but was still kind of running in the background (looking at the nvidia-smi output).
After a while I stopped the solver, because I was not expecting anything to happen anymore... (running parallel on 8 CPUs with OF v1606 did not take that long)
Output:
Exec   : simpleFoam
Date   : Sep 12 2016
Time   : 19:52:30
Host   : "INVLEVPC121"
PID    : 4999
Case   : /home/NAME/RapidCFD/NAME-dev/run/TestCase
nProcs : 1
The solver was also only using very little of the GPU, as in aee's case:
Even for this small case, one CPU core is maxed out, while nvidia-smi shows interfoam is using very little of the GPU. I may have to play with the case files to see what actually runs on the gpu.
Does anybody have an idea why this is happening?
If there are any questions about how I "compiled" RC - just ask
Old   September 14, 2016, 12:10
Per Jřrgensen
Thanks, I will try testing on a bigger problem :-)
UPDATE: Now I tried usinng it on a 2.5M cell problem, and it appears to run at the same speed as a single threaded CPU :-(
Does anybody have a test case that gives a significant speed up?
Thanks,
Per
Old   November 18, 2016, 12:22
Martin Simon
martinsimon is on a distinguished road
Did You get the issue with solver not starting resolved?
I'm having the same trouble...
How do you start using solvers when RCFD has been installed?
Using sonicFoam produces only headers, but no real action.
I can't use blockMesh under RCFD either... :/
Thanks!
Last edited by wyldckat; November 20, 2016 at 13:10. Reason: merged posts done a few minutes apart
martinsimon is offline   Reply With Quote
Old   December 8, 2016, 05:10
Default swak4Foam for RapidCFD
  #28
Jo Mar
KingKraut is on a distinguished road
Hi all,
does anyone have any experience in using swak4Foam in RapidCFD?
Anyone managed to compile this yet?
Thanks for any answers!
Best regards
Johannes
KingKraut is offline   Reply With Quote
Old   December 9, 2016, 04:19
Default Again RapidCFD swak4Foam
  #29
Jo Mar
Edit: I have opened a new thread for this, since this is not only installation of RapidCFD. Thread
__________________________________________________ ____________________________________
Hi all,
as I said I am currently trying to compile swak4Foam with RapidCFD. The system I am using is Scientific Linux 6.7.
I get the following error, when running ./Allwmake from within the folder swak4Foam:
make: *** No rule to make target `FieldValueExpressionParser.dep', needed by `Make/linux64NvccDPOpt/dependencies'. Stop.
Parser library did not compile OK. No sense continuing as everything else depends on it
I attached the full output of the command and the log from ./maintenanceScripts/compileRequirements.sh, too. Apart from that I explicitley compiled m4 version 1.4.17, as described here http://openfoamwiki.net/index.php/In...g_dependencies.
So the settings seem to be alright, I think.
I googled the error, but all I could find, was the instructions I already tried...
I am a little stuck here right now, but to me the error seems to be not caused by the combination with RapidCFD but rather some options I just did not yet set right in swak4Foam.
Can anybody point me into the right direction? Any idea, which way I could go from here?
Thanks a lot for looking into this!!
Best regards
Johannes
Old   July 22, 2017, 12:23
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear all,
I am trying to install RapidCFD but encountered some problems and thought I could find help here!
System: Ubuntu 16.04,
nvcc: NVIDIA (R) Cuda compiler driver
Cuda compilation tools, release 8.0, V8.0.61
I have GeForce GT 430 (just for testing purposes before going to a larger machine) with Nvidia drivers.
System MPI: Open MPI 1.10.2
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
I have all prerequisites of OF 2.3.1.
When I start the Allwmake script, some libraries get compiled and others don't, complaining about MPI. Although this message can be found in the output:
Note: ignore spurious warnings about missing mpicxx.h headers
I stopped the compilation process because most applications are not linking to the non compiled libraries. I herewith attach the log file. I appreciate any help for compiling on Ubuntu 16.04. Also, I would appreciate guidance to any available manual or instructions.
Thanks in advance!
Hisham
martinsimon likes this.
Hisham is offline   Reply With Quote
Old   August 25, 2017, 03:10
Ashish Magar
ashishmagar600 is on a distinguished road
Greetings everyone.
I am encountering same problems as @Hisham.
1 error detected in the compilation of "/tmp/tmpxft_00002286_00000000-5_sonicFoam.cpp4.ii".
sonicFoam.dep:3: recipe for target 'Make/linux64NvccDPOpt/sonicFoam.o' failed
make[1]: *** [Make/linux64NvccDPOpt/sonicFoam.o] Error 2
make[1]: Target '/home/magar/OpenFOAM/RapidCFD-dev/platforms/linux64NvccDPOpt/bin/sonicFoam' not remade because of errors.
make[1]: Leaving directory '/home/magar/OpenFOAM/RapidCFD-dev/applications/solvers/compressible/sonicFoam'
Most of the solvers are not compiled.
RapdiCFD was tested and used for Cuda versions 6.5 and 7.5. I don't know if it has something to do with our cuda version.
@martinsimon seems to have compiled RapidCFD but errors as:
would leave us helpless, thus switching to basic OF (without cuda).
@LisaMarie was able to compile past recently.
Yes. It would be very kind if you could help us.
I request Members and Moderators if they could help us because newer versions seem to have some disagreement with RapidCFD.
Thanks for any help.
ashishmagar600 is offline   Reply With Quote
Old   October 5, 2017, 16:53
Default [Solved]
  #32
Ashish Magar
Hello Everyone, glad to be back here.
So I contacted the developer of RC and we managed to come up with a new commit at my local branch on git-hub.
Tracking errors of not compiling the solvers were traced to uncompiled sources of reading and formatting stl files. This was due to the updated version on flex on Linux distros.
Please do the following changes in :
$Home/RapidCFD/RapidCFD-dev/src/triSurface/triSurface/interfaces/STL/readSTLASCII.L#L58
$Home/RapidCFD/RapidCFD-dev/src/surfMesh/surfaceFormats/stl/STLsurfaceFormatASCII.L#L53
from
#if YY_FLEX_SUBMINOR_VERSION < 34
to
#if YY_FLEX_MINOR_VERSION < 6 && YY_FLEX_SUBMINOR_VERSION < 34
Thanks to Daniel Jasiński (daniel-jasinski; on git-hub) for all the help.
Cheers.
Hisham likes this.
Old   November 29, 2017, 10:40
Jurado
Jurado is on a distinguished road
Hello everyone,
I am trying to install RapidCFD on ubuntu 16.04 with cuda9-0. However i am encountering an error that I can't manage to solve.
I have attached the compile log.
If someone could help me it would be really appreciated.
Thanks.
Jurado is offline   Reply With Quote
Old   March 16, 2018, 15:40
Default Pre-requisite softwares
  #34
Satish Yadav
satish000yadav is on a distinguished road
I tried installing RapidCFD earlier, but it encountered a lot of errors and didn't get installed completely.
I had installed the following before installing RapidCFD:
Nvidia CUDA, g++, gcc, alongwith those present in the third party-dev directory
Two errors(or warnings, I'm not sure) that I encountered are:
/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C: In function ‘Foam::tmp<Foam::DimensionedField<typename Foam::scalarProduct<Form, Type>::type, GeoMesh> > Foam::operator&&(const Foam::DimensionedField<Type1, GeoMesh>&, const Foam::dimensioned<Type>&)’:
/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C:648:3594: warning: typedef ‘productType’ locally defined but not used [-Wunused-local-typedefs]
PRODUCT_OPERATOR(scalarProduct, &&, dotdot)
SOURCE=sets/topoSets/cellSet.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -I/home/satish/RapidCFD/RapidCFD-dev/src/triSurface/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/surfMesh/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/fileFormats/lnInclude -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOpt/cellSet.o -c $SOURCE
other messages were similar to these.
1. Please tell me the possible reasons why I'm encountering these errors.
2. Can I get the names of softwares to be installed before installing RapidCFD?
Thanks.
satish000yadav is offline   Reply With Quote
Old   March 17, 2018, 04:59
Jurado
/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude/DimensionedFieldFunctions.C: In function ‘Foam::tmp<Foam:imensionedField<typename Foam::scalarProduct<Form, Type>::type, GeoMesh> > Foam:perator&&(const Foam:imensionedField<Type1, GeoMesh>&, const Foam::dimensioned<Type>&)’:
Thanks.
I manage to install it, so I might be able to help you (however i did not manage to have a computation working but that's something else)
Which cuda version did you use ? For I, The cuda version 9.0 did not work I had to use the 8 version
Old   March 17, 2018, 08:01
Satish Yadav
I had installed cuda 9.2, so that might be the problem, I'll retry using cuda 8. Thanks friend.
Old   March 21, 2018, 15:43
Default Errors while installing RapidCFD
  #37
Satish Yadav
Hi, I tried installing RapidCFD again, this time with cuda 8.0, I still received a lot of errors, I terminated the process and copied some of the errors which I'm pasting here:
flex wmkdep.l
make: flex: Command not found
Makefile:74: recipe for target '/home/satish/RapidCFD/RapidCFD-dev/wmake/platforms/linux64Nvcc/wmkdep' failed
make: *** [/home/satish/RapidCFD/RapidCFD-dev/wmake/platforms/linux64Nvcc/wmkdep] Error 127
Start ThirdParty Allwmake
Build MPI libraries if required
/home/satish/RapidCFD/ThirdParty-dev/Allwmake: 143: /home/satish/RapidCFD/ThirdParty-dev/Allwmake: Syntax error: ";" unexpected
+ wmakePrintBuild -check
no git description found
+ /bin/rm -f OpenFOAM/Make/linux64NvccDPOpt/global.C
+ wmakeLnInclude OpenFOAM
wmakeLnInclude: linking include files to OpenFOAM/lnInclude
+ wmakeLnInclude OSspecific/POSIX
wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude
+ Pstream/Allwmake
+ wmake libso dummy
/bin/sh: 1: /home/satish/RapidCFD/RapidCFD-dev/wmake/platforms/linux64Nvcc/wmkdep: not found
SOURCE=UPstream.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOpt/UPstream.o -c $SOURCE
/usr/include/string.h: In function ‘void* __mempcpy_inline(void*, const void*, size_t)’:
/usr/include/string.h:652:42: error: ‘memcpy’ was not declared in this scope
return (char *) memcpy (__dest, __src, __n) + __n;
UPstream.dep:3: recipe for target 'Make/linux64NvccDPOpt/UPstream.o' failed
make: *** [Make/linux64NvccDPOpt/UPstream.o] Error 1
+ set +x
wmake libso mpi
SOURCE=UOPwrite.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -DOMPI_SKIP_MPICXX -I/home/satish/RapidCFD/ThirdParty-dev/platforms/linux64Nvcc/openmpi-1.8.4/include -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOptOPENMPI/UOPwrite.o -c $SOURCE
UOPwrite.C:29:17: fatal error: mpi.h: No such file or directory
compilation terminated.
UOPwrite.dep:3: recipe for target 'Make/linux64NvccDPOptOPENMPI/UOPwrite.o' failed
make: *** [Make/linux64NvccDPOptOPENMPI/UOPwrite.o] Error 1
+ OSspecific/POSIX/Allwmake
SOURCE=signals/sigFpe.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOpt/sigFpe.o -c $SOURCE
signals/sigFpe.C: In static member function ‘static void* Foam::sigFpe::nanMallocHook_(size_t, const void*)’:
signals/sigFpe.C:70:1: warning: ‘__malloc_hook’ is deprecated [-Wdeprecated-declarations]
__malloc_hook = oldMallocHook_;
/usr/include/malloc.h:153:38: note: declared here
extern void *(*__MALLOC_HOOK_VOLATILE __malloc_hook)(size_t __size,
signals/sigFpe.C:80:1: warning: ‘__malloc_hook’ is deprecated [-Wdeprecated-declarations]
__malloc_hook = nanMallocHook_;
signals/sigFpe.C: In destructor ‘Foam::sigFpe::~sigFpe()’:
signals/sigFpe.C:150:1: warning: ‘__malloc_hook’ is deprecated [-Wdeprecated-declarations]
signals/sigFpe.C: In member function ‘void Foam::sigFpe::set(bool)’:
signals/sigFpe.C:248:1: warning: ‘__malloc_hook’ is deprecated [-Wdeprecated-declarations]
__malloc_hook = Foam::sigFpe::nanMallocHook_;
signals/sigFpe.dep:3: recipe for target 'Make/linux64NvccDPOpt/sigFpe.o' failed
make: *** [Make/linux64NvccDPOpt/sigFpe.o] Error 1
+ wmake libso OpenFOAM
SOURCE=particle/particle.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -I/home/satish/RapidCFD/RapidCFD-dev/src/meshTools/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOpt/particle.o -c $SOURCE
particle/particle.dep:3: recipe for target 'Make/linux64NvccDPOpt/particle.o' failed
make: *** [Make/linux64NvccDPOpt/particle.o] Error 1
+ wmake libso genericPatchFields
SOURCE=genericFvPatchField/genericFvPatchFields.C ; nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30 -Dlinux64 -DWM_DP -Xcompiler -Wall -Xcompiler -Wextra -Xcompiler -Wno-unused-parameter -Xcompiler -Wno-vla -Xcudafe "--diag_suppress=null_reference" -Xcudafe "--diag_suppress=subscript_out_of_range" -Xcudafe "--diag_suppress=extra_semicolon" -Xcudafe "--diag_suppress=partial_override" -Xcudafe "--diag_suppress=implicit_return_from_non_void_functi on" -Xcudafe "--diag_suppress=virtual_function_decl_hidden" -O3 -DNoRepository -D__RESTRICT__='__restrict__' -I/home/satish/RapidCFD/RapidCFD-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/satish/RapidCFD/RapidCFD-dev/src/OpenFOAM/lnInclude -I/home/satish/RapidCFD/RapidCFD-dev/src/OSspecific/POSIX/lnInclude -Xcompiler -fPIC -x cu -D__HOST____DEVICE__='__host__ __device__' -o Make/linux64NvccDPOpt/genericFvPatchFields.o -c $SOURCE
I can't figure out what's going wrong. Please help me.
Old   March 22, 2018, 04:24
Satish Yadav
I had properly cloned the RapidCFD folder from github, but I'm still not sure if the directory RapidCFD-dev/wmake is complete as I got a lot of errors indicating wmake/platforms/linux64Nvcc/wmkdep is not present.
What should be the contents of this directory?
Old   March 24, 2018, 04:34
Jurado
Well try the following :
file:
  • After installation of cuda 8.0 add in bashrc
export PATH=/usr/local/cuda-8.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
2) Install Flex
sudo apt-get install flex
3) Change the file in rapidCFD
from
to
4) Change the architecture to adapt it to your graphic card ( Compute Capacity)
aller dansRapidCFD/RapidCFD-dev/wmake/rules/linux64Nvcc
ouvrir C et C++ et changer
CC = nvcc -Xptxas -dlcm=cg -m64 -arch=sm_30
en CC = nvcc -Xptxas -dlcm=cg -m64 -arch=sm_61 (maybe yours is not 61 check it)
4) Install libz-dev
sudo apt-get install libz-dev
Then run again the installation, it worked for me, hope it will for you. But this just the install, I never managed to have a computation working . . .
Old   March 24, 2018, 13:16
Satish Yadav
Thank you so much friend! It worked.
