PotentialFoam Error
Old   May 28, 2016, 05:14
Default PotentialFoam Error
Christian
ocni is on a distinguished road
Hey guys,
I'm trying to simulate a flow through some ducts in Sim-Flow. I'm new to this software and I keep getting this error: "Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow."
My boundary conditions should be right and I use Potential Flow Initialization.
Does anyone have an idea to fix this?
Thanks!
PS. I tried to insert a picture of the error message. It doesn't seem to work. So here is a link http://imgur.com/usDHKU9
ocni is offline   Reply With Quote
Old   May 31, 2016, 08:42
Lennart
elmo555 is on a distinguished road
Hey Christian,
you said that your boundary conditions "should be right". How exactly did you set the BCs? Do you have an outlet?
elmo555 is offline   Reply With Quote
Old   May 31, 2016, 10:49
Christian
Yes, I have an outlet defined as an outflow.
Old   May 31, 2016, 10:53
Lennart
In both the pressure and velocity field?
initialization, potentialfoam, simflow
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
