How to run unsteady simulation in OpenFOAM?
Old   August 1, 2016, 13:00
Default How to run unsteady simulation in OpenFOAM?
Usman Ashraf
usman89 is on a distinguished road
Hi
I am doing my thesis on wind turbine wake analysis using OpenFOAM. The method I have to use is a fully resolved rotor method, i.e. direct method with the full turbine model.
So far I have been simulation with RANS approach, k omega SST and SimpleFOAM solver.
However, I have read that I have to do an unsteady analysis, read somewhere that it involves URANS.
Anyone able to shed some light on this please? Or do I simply run RANS approach with a different solver?
Many thanks
U
usman89 is offline   Reply With Quote
Old   August 12, 2016, 10:26
Tobi's Avatar
Tobias Holzmann
Unsteady means that you solve in time (you are interested of the time evaluation). Therefore you should use PIMPLE or PISO solver. In the newer versions there is only the xxxPimpleFoam available that can operate in PISO mode too.
A xxxSimpleFoam solver is normaly solving for steady-state and hence we have no time derivative that we take into account. If you don't know if a solver solves for a steady or unsteady problem. Check the equations in the source code and the fvSchemes for ddt and/or d2dt.
Keep foaming,
Tobias Holzmann
error to check simulation result: could not find valid OpenFOAM mesh xiaoyoyo OpenFOAM 5 May 18, 2017 11:38
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 04:37
