PostProcess "0/uniform" data
Old   September 17, 2016, 12:47
Default PostProcess "0/uniform" data
nusivares is on a distinguished road
Hi all,
I am struggling to find the information how to postprocess the uniform data into a CSV file on OpenFOAM. Essentially I have a transient analysis runs with the source term added as fvOptions into the momentum equation. This term is then saved into somthing similar to "0/uniform/momentumSourceProperties.gz"
Essentially I want to extract it against the time into a csv.
This proves fairly stressful and I am in a desperate need for help.
nusivares is offline   Reply With Quote
Old   September 19, 2016, 09:04
C-L
Charlie Lloyd
C-L is on a distinguished road
Hi Nusivaries,
Is the momentum source term also printed in the log file as the code runs? If so you can use Unix code similar to that found in the link below to extract both run time and the pressure gradient term.
http://www.cfd-online.com/Forums/ope...residuals.html
That is how I have done it in the past!
C-L is offline   Reply With Quote
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 02:47
how to pickup the mesh data and vector data oga_shin OpenFOAM 2 October 27, 2011 23:42
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
