Rotating Mesh, errors in Cyclic AMI interface
Old   September 26, 2016, 05:46
Default Rotating Mesh, errors in Cyclic AMI interface
WhiteW is on a distinguished road
Hi Foamers, I’m trying to simulate a 2D Vertical Axis Wind Turbine analysis in OpenFoam 4.0, but I’m having some troubles with cyclic AMI interface.
I have created two different meshes with Salome (Rotor and WindTunnel) and exported to OpenfOAM in *.unv format. (I have also exported them directly to OpenFOAM using the python script salomeToOpenFOAM, however the described situation is the same.)
For both these meshes I specified the surface of rotating cylinder as a face patch.
I created two OpenFAOAM folders (for rotor and WindTunnel) and in each of them I run:
ideasUnvToFoam Mesh_1.unv
ideasUnvToFoam WinTunnel.unv
Then I merge the meshes in the master case using:
mergeMeshes OpenFOAM-2D-VAWT-RO/ OpenFOAM-2D-VAWT-WT/  > log.mergeMeshes
And I use createPatch to couple the interfaces:
createPatch -overwrite > log.createPatch
Everything seems to work fine, the simulation starts, the rotor zone rotates correctly, however I notice strange results, as in the attached picture.
In the complete case, the interfaces seem to be walls and the interpolation is not correct since the streamlines in the rotating part are completely different than the outside streamlines.
I have also tried another setting:
If, in the meshes generation, I split the cylindrical interface in two half (upper part and lower part) and then I couple them with two cyclicAMI interfaces, I noticed that in OpenFOAM the renumberMesh command does not work and it gives an error about the matching of the source and target surfaces.. But they are perfectly identical, if check the mesh in Salome or if I open the mesh in Paraview. I can’t explain this..
 From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>]
    in file lnInclude/AMIMethod.C at line 57
    Source and target patch bounding boxes are not similar
    source box span     : (1.6 0.8 0.01)
    target box span     : (0.961359 1.58354 0.01)
    source box          : (-0.8 7.34788e-17 0) (0.8 0.8 0.01)
    target box          : (-0.799999 -0.799984 0) (0.16136 0.783558 0.01)
    inflated target box : (-0.892626 -0.892611 -0.0926271) (0.253987 0.876185 0.102627)
Anyone can help me? Is my procedure correct?
Thanks,
WhiteW
WhiteW is offline   Reply With Quote
Old   September 26, 2016, 09:05
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Please provide the necessary files:
  • createPatchDict
  • boundary
  • U file
Otherwise we are not able to help you. I never used mergeMesh (maybe I should) but if you merge the meshes, are the boundaries of both still there or not? If they are there, you do not need to execute createPatch. If you mesh is moving with moveDynamicMesh and everything is fine, you should only have a problem with the correct boundary conditions.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   September 26, 2016, 09:12
Hi Tobi, thanks for replying.
I just realized that the problem was the definition of the patches in createPatchDict. The setting I was using was wrong:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
pointSync false;
patches
        name  per_int_E;
        patchInfo
            type cyclicAMI;
            neighbourPatch per_int_I;
            transform rotational;
            rotationAxis (0 0 1);
            rotationCentre (0 0 0);
            matchTolerance 1E-1;
        constructFrom patches;
        patches (IntCirc_extruded);
        name per_int_I;
        patchInfo
            type cyclicAMI;
            neighbourPatch per_int_E;
        patches (Internal1);
        name Blade_extruded_1;
        patchInfo
            type            wall;
        patches (Blade_extruded);
        name Blade_extruded_rotated_1;
        patchInfo
            type            wall;
        patches (Blade_extruded_rotated);
        name Rotor_Top_1;
        patchInfo
            type            empty;
        patches (Rotor_Top);
        name Rotor_Bot_1;
        patchInfo
            type            empty;
        patches (Rotor_Bot);
        name PiaWT_1;
        patchInfo
            type            empty;
        patches (PiaWT);
        name WC_PiaWT_Top_1;
        patchInfo
            type            empty;
        patches (WC_PiaWT_top);
        name Sides_extruded_1;
        patchInfo
            type            symmetry;
        patches (Sides_extruded);
I was using the option "transform rotational;" for the AMIpatches, the correct option is:
            transform       noOrdering;
Now it works fine,
WhiteW
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
