Looking for "Derivation [...] of the conditionally averaged two-phase flow equations"
Like Tree7Likes
  • 2 Post By mxylondon
  • 4 Post By aunola
  • 1 Post By Cyp
Old   November 12, 2015, 05:06
Default Looking for "Derivation [...] of the conditionally averaged two-phase flow equations"
X Meng
mxylondon is on a distinguished road
Dear Foamers,
Does anyone have refrence paper <Derivation, modelling and solution of the conditionally averaged two-phase flow equations> form Mr HG Weller?
Great thanks!!!
Regards
Kummi and tukkuezgi like this.
mxylondon is offline   Reply With Quote
Old   November 22, 2015, 07:21
Retired Super Moderator
Bruno Santos
Quick question: Have you tried the contact form at CFD Direct? http://cfd.direct/contact/
It's where Henry Weller works at: http://cfd.direct/about/
Old   October 18, 2016, 02:49
Martin Aunskjaer
aunola is on a distinguished road
I have seen this report being requested a number of times. While it appears unavailable, the process of conditional averaging is well described in works of other authors. Particularly lucid treatments can be found in [1, ch. 2] and [2, ch.1.6 + appendix A]. There is also a report by Weller [3] in which he treats this subject. The idea of conditional averaging is based on the work of Dopazo [4] for turbulent flows.
[1] Holger Marschall, “Towards the Numerical Simulation of Multi-Scale Two-Phase Flows”, PhD thesis, München, 2011
https://mediatum.ub.tum.de/doc/1080878/1080878.pdf
[2] David Paul Hill, ”The Computer Simulation of Dispersed Two-phase Flows”, PhD thesis, London, 1998
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/DavidHillPhD1998.pdf
[3] H.G. Weller, “The Development of a New Flame Area Combustion Model Using Conditional Averaging”, Imperial College, London, 1993
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.45.6303&rep=rep1&type=pdf
[4] C. Dopazo, On conditional averages for intermittent turbulent flows, Journal of Fluid
Mechanics 81 (1977) 433-438.
aunola is offline   Reply With Quote
Old   October 18, 2016, 23:15
Cyp
Cyprien
Cyp is on a distinguished road
You may also look at this short note on the derivation of continuity equation for VOF with mass transfer
or look at this Master thesis, Chap3
These derivations are based on the method of volume averaging (integration on volume, including the boundary effects as body forces).
Cheers
GautCFD likes this.
Cyp is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
2 Phase Flow, Gas Jet into Water Simulation Method im_lenny OpenFOAM 3 May 4, 2017 03:20
Divergence in Two phase flow in impeller for Cavitation joshghoun Fluent Multiphase 2 November 5, 2014 09:33
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 07:33
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
