dynamic mesh case: dynamicRefineFvMesh
Like Tree1Likes
  • 1 Post By Dipsomaniac
Old   October 21, 2016, 18:49
Default dynamic mesh case: dynamicRefineFvMesh
Nevada
razi.me05 is on a distinguished road
Hi I'm trying to implement a dynamic mesh case in openfoam (oscillating deforming sharp-edge structure: deformation is prescribed by me). I want to use dynamicRefineFvMesh since I need mesh refinement. I have two questions regarding this method. I'd really appreciate your help.
1. Does the dynamicRefineFvMesh works similar to remeshing in Fluent?
2. Is there a way to refine mesh depending on the node displacement instead of the value of the field(it allows only p and nu for my case)?
razi.me05 is offline   Reply With Quote
Old   October 25, 2016, 05:21
Brian Willis
Dipsomaniac is on a distinguished road
Hello
Note that OpenFOAM doesn't currently support dynamic motion and refinement simultaneously.
The dynamic refinement works by adding cells around an interface such as the interface between two fluids. It can also be programmed to refine around other scalar values, or against two parameters if you look at the work done by Tobias @ http://www.holzmann-cfd.de/index.php...efinefvmesh-en .
Regards,
Brian
Tobi likes this.
Dipsomaniac is offline   Reply With Quote
dynamic mesh, dynamicrefinefvmesh, field
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
