reactingTwoPhaseEulerFoam and chemical reations
Old   October 27, 2016, 01:37
Default reactingTwoPhaseEulerFoam and chemical reations
M.H. Radanielina
RamCmd is on a distinguished road
Hi Foamers,
I am currently working on gasification process, and using reactingTwoPhaseEulerFoam solver (in multiphase/reactingEulerFoam) and bubbleColumnEvaporatingReacting as the basis of my case.
In bubbleColumnEvaporatingReacting/constant/reactions.gas folder, there are :
species
CO
CO2
H2
H2O
AIR
reactions
waterGasShift
type reversibleArrheniusReaction;
reaction "CO^0.93 + H2O^0.24 = CO2^0.69 + H2^1";
A 1e8;
beta 0.86;
Ta 1e4;
The case I would like to develop consists of 4 main reactions :
C(CHAR) + H2O => CO + H2
CO + H2O <=> CO2 + H2
C(CHAR) + CO2 => 2CO
C(CHAR) + 2H2 => CH4
I started to modify liquid terms to particle in the tutorial case knowing that in my case I have two phases namely gas and particle dispersed (interpreting as a continuum fluid). And I run my case and it compiled very well. But I do not make change in reactions, phaseProperties and thermophysicalProperties in order to implement my reactions, define my phases or species properties.
So my questions are, how can I implement my species and reactions and parametrize thermophysicalProperties and phaseProperties in my case (gas and particle fluid phases)?
I see there is thermo.gas file where the gas species in the reactions are defined. But in my case, there is C(CHAR) which is a solid particle not a gas and I would like to know how can I define it, in another file I will create or what?
Thanks in advance for your reply
Best regards
RamCmd is offline   Reply With Quote
chemical reactions, gasification cfd, reactingtwophaseeulerfoam, thermophysicalproperties
How are chemical reactions stored after parsing? DanielW OpenFOAM Programming & Development 3 June 7, 2018 14:39
chemical reaction in stead of combustion wlt_1985 FLUENT 3 June 11, 2012 04:55
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
chemical reaction - howto Dan Sorensen Siemens 1 February 21, 2000 09:20
