January 18, 2019, 04:32 |
Viscosity and pressure - Newtonian
Zander Meiring
Rep Power: 7 |
Good day all,
I am using the simpleFoam solver with a Newtonian transport model, where only kinematic viscosity is needed (nu). After solving, my main point of consideration is pressures, which is by default given as P/rho. I am working with air at 15C so nu = 1.47e-5 mu = 1.802e-5 rho = 1.225 Would there be any negative consequence to changing the properties such that I set rho = 1, and therefore use a nu = 1.802e-5? This would mean that my pressures don't need to be multiplied by density, but I am unsure if this would cause differences in regards to the turbulence models when computing turbulent viscosity. |
January 18, 2019, 06:16 |
Henrik Johansson
Rep Power: 8 |
Hi Zander,
Density is not solved with simpleFoam. The effect of density is as you said pressure(in OpenFoam) = P/rho. Thus your indata for pressure shall be P divided by density of your fluid. Changing density to 1 would be unphysical if you are trying to solve air at 15C.
/ Henrik Johansson |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
interFoam: strange pressure with high fluid viscosity? | ckroener | OpenFOAM | 3 | April 7, 2010 12:51 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
