Viscosity and pressure - Newtonian
Old   January 18, 2019, 05:32
Default Viscosity and pressure - Newtonian
Zander Meiring
yambanshee is on a distinguished road
Good day all,
I am using the simpleFoam solver with a Newtonian transport model, where only kinematic viscosity is needed (nu).
After solving, my main point of consideration is pressures, which is by default given as P/rho. I am working with air at 15C so
nu = 1.47e-5
mu = 1.802e-5
rho = 1.225
Would there be any negative consequence to changing the properties such that I set rho = 1, and therefore use a nu = 1.802e-5? This would mean that my pressures don't need to be multiplied by density, but I am unsure if this would cause differences in regards to the turbulence models when computing turbulent viscosity.
yambanshee is offline   Reply With Quote
Old   January 18, 2019, 07:16
Henrik Johansson
HenrikJohansson is on a distinguished road
Hi Zander,
Density is not solved with simpleFoam. The effect of density is as you said pressure(in OpenFoam) = P/rho.
Thus your indata for pressure shall be P divided by density of your fluid. Changing density to 1 would be unphysical if you are trying to solve air at 15C.
/ Henrik Johansson
HenrikJohansson is offline   Reply With Quote
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 19, 2018 00:39
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
interFoam: strange pressure with high fluid viscosity? ckroener OpenFOAM 3 April 7, 2010 13:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
