Creating a solver for the nondimensionalized Navier-Stokes equation
Like Tree12Likes
Old   November 15, 2012, 10:52
Question Creating a solver for the nondimensionalized Navier-Stokes equation
Sami
Mehrez is on a distinguished road
Hi everyone,
I have recently started using OpenFoam.
I want to resolve the nondimensionalized Navier-Stakes equation (in which appears the Reynolds number).
My equation is ( you can also find it attached ) : Re . (U . div) U + grad(meanP) - laplacian(U) = - grad(fluctP)
meanP is a unit vector which is constant and P=meanP+fluctP
Re is the reynolds number
I want to resolve my equation for U and fluctP
For this, I have modified the IcoFoam solver as follows, but it seems that there is an error ( may be with the '' meanP '' )
fvVectorMatrix UEqn
fvm::ddt(U)
+ Re*(fvm::div(phi, U))
- fvm::laplacian(U)
+ magSqr(meanP)
solve(UEqn == -fvc::grad(fluctP));
I will be thankfull If someone can help me to create this solver or share a web site which treated the implementation of the nondimensionalized NS equation.
Best regards
Mehrez
Mehrez is offline   Reply With Quote
Old   November 16, 2012, 04:01
Sami
Hi
Can someone help me please.
Thank you
Old   November 16, 2012, 04:49
Sami
please find attached the OpenFoam files of the solver (I have proceeded by modifying the IcoFoam solver to myIcoFoamB solver).
Old   November 16, 2012, 05:39
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
there are many errors:
fvVectorMatrix UEqn
              fvm::ddt(U)
            - fvm::laplacian(U)
            + magSqr(meanP)
First: laplacian(U) is not a class. If you use laplacian you have to a coefficent like:
laplacian(nu, U)
You set Re as reynoldsnumber. But the solver do not know what "Re" is. Its a none declared variable. The same like magSqr(meanP)
OF do not know what meanP is.
So you have to define
Re
meanP
and the other variables you implemented!
The following example is working:
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
          - fvc::grad(p)
        solve(UEqn == -fvc::grad(p));
Tobi is offline   Reply With Quote
Old   November 16, 2012, 05:50
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi Mehrez,
First it would be better if you modify the Make/files as in the user guide chapter 3 to be:
myIcoFoamB.C
EXE = $(FOAM_USER_APPBIN)/myIcoFoamB
When I try to compile your solver (initially) two errors occur from different places. This points out that you have made a punch of modifications then decided to compile ... Not a good idea .. It is always a good practice to compile regularly after small code changes to keep track of code bugs early on. It is a little bit tedious but very efficient. Back to the errors:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:23:5: error: no matching function for call to ‘Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField\
, Foam::volMesh>::GeometricField(Foam::ITstream&)’
createFields.H:23:5: note: candidates are:
Then the compiler gives you some ideas about what could be the problem. Anyway the code that caused this error is:
volVectorField gradP
        transportProperties.lookup("gradP")
Essentially this is not how you declare a volVectorField. The compiler is complaining that there is no lookup function for the volVectorField and if there were one (which isn't the case) you are doing it wrong and hence the error. volVectorField are defined like the p if you'll read as user input but if you need to calculate:
        IOobject
            "gradP",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
    fvc::grad(p)
The second error:
myIcoFoamB.C:61:18: error: no match for ‘operator+’ in ‘Foam::operator-(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam\
::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>]((*(const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > \
>*)(& Foam::fvm::laplacian(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<\
double>]()))) + Foam::magSqr(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, Pat\
chField = Foam::fvPatchField, GeoMesh = Foam::volMesh]()’
myIcoFoamB.C:61:18: note: candidates are:
Comes from the eq:
fvVectorMatrix UEqn
            fvm::ddt(U)
          - fvm::laplacian(U)
	  + magSqr(gradP)
Maybe it will be solved if you fix the first one or not ...
Best regards,
Hisham
Tobi likes this.
Hisham is offline   Reply With Quote
Old   November 16, 2012, 06:34
Tobi's Avatar
Tobias Holzmann
Originally Posted by Hisham View Post
Hi Mehrez,
fvVectorMatrix UEqn
            fvm::ddt(U)
          - fvm::laplacian(U)
      + magSqr(gradP)
Best regards,
Hisham
Hi Hisham, the laplacian class is wrong like I posted befor.
I just had a very short look into the code and dont see the declaration of the other variables
Well nice replay!
            fvm::ddt(U)
      + magSqr(gradP)
Old   November 16, 2012, 06:43
Sami
Hi guys
Thank you for your help.
I think that it is better if you take a look to my equation (which I have attached in my first message). You can see that I don't have : nu . laplacian (U) but I just have : laplacian (U)
Concerning the declaration of the variables : I have declared " Re " and " gradP " in the file createFields.H
dimensionedScalar Re
transportProperties.lookup("Re")
Old   November 16, 2012, 06:50
Tobi's Avatar
Tobias Holzmann
Oh sorry,
the laplacian(U) class existis! So its working
Mehrez likes this.
Old   November 16, 2012, 06:58
Sami
Hi Hisham
Thank you for your answer.
I think that I don't have to declare " gradP " like this :
volVectorField gradP ( IOobject ( "gradP", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), fvc::grad(p) );
As I said before, the '' gradP '' is a unit vector which is constant and which I put it like an input (so this is why OF don't have to compute it).
I have just to declare it like a vector which I will specify the value in constantProperties file.
Old   November 16, 2012, 07:01
Tobi's Avatar
Tobias Holzmann
Originally Posted by Mehrez View Post
Hi Hisham
As I said before, the '' gradP '' is a unit vector which constant and which I put it like an input (so this is why OF don't have to compute it).
Hmmm ... you calculate your gradP field with grad(p) or?
But how whould you get the information of the "vector" couse the pressure is just a scalar without a direction.
Old   November 16, 2012, 07:06
Sami
Hi Tobi
As you can see in my equation gradP is the gradient of the nondimensionalized mean pressure. I have it like an input (I will study my flow in function of given values of Re and gradP)
I think that the problem is how to define this vector (gradP) in the equation
Old   November 16, 2012, 07:15
Sami
I think that it is more clear like this
Equation : Re . (U . div) U + gradP - laplacian(U) = - grad(fluctP)
OF syntax :
fvVectorMatrix UEqn
fvm::ddt(U)
- fvm::laplacian(U)
+ magSqr(gradP)
Input :
Re : scalar
gradP : vector
output (after computation)
U : vector field
fluctP : vector field
Old   November 16, 2012, 10:22
Bernhard
Bernhard is on a distinguished road
If gradP is a constant vector, you should not store it in a volVectorField, but in a dimensionedVector from the transportproperties.
Two more things:
- Are you sure Reynolds should appear like you wrote it. As far as I know, in the dimensionless NS equations, you have 1/Re in the diffusive terms.
- You're now adding magSqr(gradP), which is a scalar, to a vector equation. This can not be correct.
Mehrez likes this.
Bernhard is offline   Reply With Quote
Old   November 16, 2012, 10:52
Sami
Dear Bernhard,
I'm sure that I have a right equation (attached here)
Thank you very much for your help. Actually I can compile my solver with your corrections.
fvVectorMatrix UEqn
fvm::ddt(U)
- fvm::laplacian(U)
+ gradP
and :
dimensionedVector gradP
To test this solver, I've taken the attached example "cavity" after putting U, p, Re, and gradP in a dimensionless form. I've done the same with the domain (I've commented the line " conversion to meters " ).
Executing "cavity" with "myIcoFoamB" solver, OpenFoam returns an error message on the dimensions:
-> FOAM FATAL ERROR:
incompatible dimensions for operation
[U [0 -1 0 0 0 0 0]] - [U [0 -2 0 0 0 0 0]]
I think it comes from the operators (grad gives : L ^ -1 and Laplacian gives : L ^ -2). Is there a way to put the components (x, y, z) of the domain in a dimensionless form in order to get dimensionless values ​​by applying one of the operators?
Best regards.
Mehrez
Old   November 16, 2012, 11:24
Bernhard
Complicated one, you can choose to ignore the dimension-checking. I think you can do this in the controlDict you find in ..../OpenFOAM-2.1.x/etc/ .
Maybe you can put it in your own controlDict as well. I never tested this, but you can look here.
Mehrez likes this.
Old   November 16, 2012, 11:31
Tobi's Avatar
Tobias Holzmann
you can put a dimensionSet on your p vector that the dimension check is working!
Tobi
Mehrez likes this.
Old   November 16, 2012, 11:43
Sami
Hi guys,
Again thanks for your precious help.
@ Bernhard : I have found the file " controlDict " , can you please precise me how to proceed.
@ Tobi : I've tried what you said but it doesn't work. it returns each time a different dimensions error ! I can't understand
Mehrez
Old   November 16, 2012, 11:50
Tobi's Avatar
Tobias Holzmann
Post your dimenionSet and the output error.
Old   November 16, 2012, 11:56
Sami
Re Re [ 0 0 0 0 0 0 0 ] 0.01;
gradP gradP [ 0 0 0 0 0 0 0 ] (0.9 0.2 0);
U : dimensions [0 0 0 0 0 0 0];
p : dimensions [0 0 0 0 0 0 0];
In the blockMeshDict, I have commented the following line :
//convertToMeters 0.1;
and this is what I get :
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
--> FOAM FATAL ERROR:
[U[0 -1 0 0 0 0 0] ] - [U[0 -2 0 0 0 0 0] ]
From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
in file /opt/openfoam211/src/finiteVolume/lnInclude/fvMatrix.C at line 1316.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/myIcoFoamB"
#5 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Aborted (core dumped)
ubuntu@ubuntu-VirtualBox:~/OpenFOAM/mehrez-2.1.1/test/cavity$
Old   November 16, 2012, 11:58
Tobi's Avatar
Tobias Holzmann
What is that:
??? I dont understand the two lines.
Set
pGrad pGrad [0 -1 0 0 0 0 0]
navier-stokes solver, openfoam
suGWFoam: Richards equation solver for porous media flows liu OpenFOAM Announcements from Other Sources 4 February 10, 2021 15:14
Navier Stokes solver Siddharth Main CFD Forum 2 September 13, 2007 01:06
test prob for 2D unsteady navier stokes equation Shah Main CFD Forum 5 April 20, 2007 07:25
Navier Stokes Solver Khan Main CFD Forum 2 December 12, 2006 09:41
help: I am trying to solve Navier Stokes compressible and viscid flow Jose Choy Main CFD Forum 2 May 18, 2000 05:45
