June 14, 2017, 15:15 |
blockMeshdict
ABHINAVMOHAN
Rep Power: 8 |
Point (3.0001 3.0001 0.43) is not inside the mesh or on a face or edge.
Bounding box of the mesh0 600 0) (2000 2000 3000) getting this error I guess it is a simple one !!!! \ thank you |
June 14, 2017, 17:11 |
Brian Willis
Rep Power: 15 |
Your Y coordinate is not within the bounds.
June 15, 2017, 06:59 |
ABHINAVMOHAN
Rep Power: 8 |
okay I have an STL file with bounding box coordinates
Bounding Box : (648.269 661.283 0) (1518.03 1708.36 2014.5) how do I make sure that my STL file is inside that blockMesh? |
June 15, 2017, 14:07 |
Into your terminal type
Blockmesh touch 1.foam paraview 1.foam Code:
Apply File --> open --> constant/triSurface/yourFile.stl Apply Last edited by student666; June 15, 2017 at 15:12. |
June 19, 2017, 04:20 |
ABHINAVMOHAN
Rep Power: 8 |
thanks, man
June 19, 2017, 07:16 |
ABHINAVMOHAN
Rep Power: 8 |
convertToMeters 1;
vertices ( (48 660 -2015) (2000 660 -2015) (2000 3000 -2015) (48 3000 -2015) (48 660 4000) (2000 660 4000) (2000 3000 4000) (48 3000 4000) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type patch; faces ( (0 4 7 3) (2 6 5 1) ); } inlet { type patch; faces ( (4 5 6 7) ); } outlet { type patch; faces ( (0 3 2 1) ); } lowerWall { type wall; faces ( (1 5 4 0) ); } upperWall { type patch; faces ( (3 7 6 2) ); } ); this is my blockMeshdict i am still getting the same error |
June 19, 2017, 16:29 |
#8 | |
So your blockMeshDict has to be a cube bigger that contains the bounding box of the STL file. You have to rearrange position of the vertexes. Some notes: 1 - I still can't figure out what you're trying to do, are you using snappyHexMesh? 2 - If I were you, I would have a further reading of the user guide.. 3 - If point 2 is not enough I think that google can help you with this issue; by these times there are many video tutorials that can help you 4 - if point 1 is true, then https://www.google.it/url?sa=t&rct=j...G0TqQaKFG0MCGw ... it's a good starting point Good luck. |
June 20, 2017, 14:36 |
#9 | |
ABHINAVMOHAN
Rep Power: 8 |
i have read that i tried on the basis of it still cant figure this out would you please help me out and yes i am using snappyHexMesh as you can see that my stl file is inside bounding box. i studied what you told me to according to the best of my knowledge i was able to work through my way espically with bonding box the error which i get is it is showing the same problem i have attached my blockmeshdict bounding box.PNG bounding box2.PNG error.PNG b1.PNG b2.PNG |
June 20, 2017, 15:59 |
#10 |
Ok, so with this picture I can see that stl file is inside your background mesh, but openfoam is complaining about your
locationInMesh (3.0001 3.0001 0.48) I build your backgoround mesh and the point that is not inside the mesh (the sphere). It is now easier to see that the point is not inside the mesh... You have to move your Code:
locationInMesh |
June 20, 2017, 16:25 |
#11 |
ABHINAVMOHAN
Rep Power: 8 |
what all do you need?
June 20, 2017, 16:35 |
#13 |
ABHINAVMOHAN
Rep Power: 8 |
June 21, 2017, 17:18 |
#14 |
ABHINAVMOHAN
Rep Power: 8 |
hey sorry to bother you again
but I tried everything it just doesn't work |
June 21, 2017, 17:36 |
#15 |
Brian Willis
Rep Power: 15 |
Can you upload your case folder perhaps?
June 21, 2017, 17:40 |
#16 |
ABHINAVMOHAN
Rep Power: 8 |
there you go
as you would have seen from previous conversation that i had with student 666 it seems like my stl file is very much inside the block but i cant figure this location in mesh thing i have attached both the files blockMeshDict.txt snappyhexmesh.txt |
June 21, 2017, 17:47 |
#17 |
Brian Willis
Rep Power: 15 |
Try something like this
locationInMesh (51.00235 662.000231 -2000.00234); |
June 21, 2017, 17:48 |
#18 |
ABHINAVMOHAN
Rep Power: 8 |
same error sorry
June 21, 2017, 18:21 |
#19 |
Brian Willis
Rep Power: 15 |
I can recreate your original error
--> FOAM FATAL ERROR: Point (3.0001 3.0001 0.43) is not inside the mesh or on a face or edge. Bounding box of the mesh:(48 660 -2015) (2000 3000 4000) From function Foam::labelList Foam::refinementParameters::findCells(const Foam::polyMesh&) const in file snappyHexMeshDriver/refinementParameters/refinementParameters.C at line 103. FOAM exiting |
June 21, 2017, 18:45 |
#20 |
ABHINAVMOHAN
Rep Power: 8 |
i am sending you my case through private message or you could provide me your email-id?
[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs? | chrisb2244 | OpenFOAM Meshing & Mesh Conversion | 0 | December 1, 2014 23:52 |
[Other] blockMeshDict not Matching Boundary | HassanDarian | OpenFOAM Meshing & Mesh Conversion | 0 | March 19, 2014 13:30 |
[blockMesh] OpenFOAM blockMeshDict | sihaqqi | OpenFOAM Meshing & Mesh Conversion | 2 | February 1, 2013 03:49 |
PLease somebody help:problem while changing blockMeshDict file | vivek070176 | OpenFOAM Installation | 1 | June 11, 2010 17:51 |
[blockMesh] A script for combining two blockMeshDict | yingfeng | OpenFOAM Meshing & Mesh Conversion | 0 | August 26, 2009 16:05 |
