PRefCell not constant
Old   June 6, 2017, 12:42
Default PRefCell not constant
C-L
Charlie Lloyd
C-L is on a distinguished road
Hi all,
I am simulating a fully developed channel flow using RANS and cyclic boundary conditions. In order to do so I need to specify a reference pressure at a certain location. I have chosen a cell on one of the wall boundaries to have a reference pressure of 0 BUT after checking the converged solution the pressure at this cell is 0.029. I assumed the reference cell would maintain the reference pressure throughout the whole simulation - is this not the case?
Thanks in advance.
C-L is offline   Reply With Quote
Old   June 11, 2017, 14:47
khedar
khedar is on a distinguished road
Just wondering, is it okay to put reference cell on the wall? Since normally we apply zeroGradient condition on the wall.
khedar is offline   Reply With Quote
Old   June 11, 2017, 14:58
C-L
Charlie Lloyd
I assumed that it wouldn't matter but you might be right. However, I'm not sure where else to put the reference point in a periodic channel. I need to be able to calculate forces on the wall so wouldn't they be dependent on the pressure field? And wouldn't changing the reference point subsequently change the force calculations?
Thanks for the reply.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 05:46
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 11:15
