pimpleDyMFoam moving mesh error
Old   May 14, 2017, 14:28
Default pimpleDyMFoam moving mesh error
Pouria Taghikhani
Taghi is on a distinguished road
Hi all
I am trying to simulate a ducted propeller with pimpleDyMFoam solver. There is no problem with propeller alone. But when I try to add the duct and solve it again, solver stops.
I am now trying to figure the problem by using:
 runApplication moveDynamicMesh -checkAMI
(as openfoam tutorials suggested)
but the following message apears:
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 4.x-ed69f631ce88
Exec   : C:/PROGRA~1/BLUECF~1/OpenFOAM-4.x/platforms/mingw_w64GccDPInt32Opt/bin/moveDynamicMesh.exe -checkAMI
Date   : May 14 2017
Time   : 21:54:08
Host   : "DESKTOP-PU3N81D"
PID    : 5112
Case   : C:/Users/Pouria/Desktop/propeller400
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone innerCylinderSmall
Writing VTK files with weights of AMI patches.
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
forces Rotor:
--> FOAM Warning :
    From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 794
    Cannot find any patch or group names matching propellerRotor
    Not including porosity effects
forces DAS:
--> FOAM Warning :
    Cannot find any patch or group names matching propellerDuct
Time = 5e-006
PIMPLE: iteration 1
--> FOAM Warning :
    From function virtual bool Foam::solidBodyMotionFvMesh::update()
    in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 228
    Did not find volVectorField U Not updating Uboundary conditions.
PIMPLE: iteration 2
    Point usage OK.
    Upper triangular ordering OK.
    Topological cell zip-up check OK.
    Face vertices OK.
  <<Number of duplicate (not baffle) faces found: 2. This might indicate a problem.
  <<Number of faces with non-consecutive shared points: 3. This might indicate a problem.
    Mesh topology OK.
    Boundary openness (3.72253e-016 -9.13045e-017 9.01232e-017) OK.
    Max cell openness = 4.35445e-016 OK.
    Max aspect ratio = 11.8457 OK.
    Minimum face area = 3.57658e-009. Maximum face area = 0.00294544.  Face area magnitudes OK.
    Min volume = 9.05772e-011. Max volume = 0.000110349.  Total volume = 1.31244.  Cell volumes OK.
    Mesh non-orthogonality Max: 64.9606 average: 9.12233
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 3.94105 OK.
    Mesh geometry OK.
Mesh OK.
Calculating AMI weights between owner patch: AMI1 and neighbour patch: AMI2
AMI: Creating addressing and weights between 45130 source faces and 46232 target faces
AMI: Patch source sum(weights) min/max/average = 0.0734142, 2.13295, 0.999935
AMI: Patch target sum(weights) min/max/average = 0, 1.84503, 0.999232
ExecutionTime = 39.753 s  ClockTime = 40 s
--> FOAM FATAL ERROR:
Could not find U, p
    From function void Foam::functionObjects::forces::initialise()
    in file forces/forces.C at line 186.
FOAM exiting
and this is pimpleDyMFoam error:
|  \\    /   O peration     | Version:  4.1                                   |
Build  : 4.1
Exec   : pimpleDyMFoam -parallel
Date   : May 15 2017
Time   : 12:40:46
Host   : "pouria"
PID    : 3167
Case   : /home/pouria/Desktop/propeller400
nProcs : 4
Slaves :
3
"pouria.3168"
"pouria.3169"
"pouria.3170"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
Create time
Reading field p
Reading field U
AMI: Creating addressing and weights between 45146 source faces and 46392 target faces
AMI: Patch source sum(weights) min/max/average = 0.565692, 2.10459, 1.00072
AMI: Patch target sum(weights) min/max/average = 0, 1.84453, 0.998807
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
bounding k, min: 0 max: 0.06 average: 0.06
bounding epsilon, min: 0 max: 0.0495 average: 0.0495
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
Reading/calculating face velocity Uf
No finite volume options present
Courant Number mean: 6.98835e-07 max: 0.00055208
forces propellerTip:
forces DAS:
Starting time loop
deltaT = 1e-05
Time = 1e-05
AMI: Patch source sum(weights) min/max/average = 0.00638659, 2.10717, 1.00071
AMI: Patch target sum(weights) min/max/average = 0, 1.84552, 0.998866
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0302785, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.000126242, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0305505, No Iterations 1
[1] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
[1] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
[1] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[1] #5  ? at ??:?
[1] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #7  ? at ??:?
[pouria:03168] *** Process received signal ***
[pouria:03168] Signal: Floating point exception (8)
[pouria:03168] Signal code:  (-6)
[pouria:03168] Failing at address: 0x3e800000c60
[pouria:03168] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f15358094b0]
[pouria:03168] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f1535809428]
[pouria:03168] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f15358094b0]
[pouria:03168] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKdRKNS_5UListIdEE+0x114)[0x7f1536c46264]
[pouria:03168] [ 4] pimpleDyMFoam(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKNS_11dimensionedIdEERKS8_+0x1d7)[0x474ba7]
[pouria:03168] [ 5] pimpleDyMFoam[0x4259ac]
[pouria:03168] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f15357f4830]
[pouria:03168] [ 7] pimpleDyMFoam[0x4286c9]
[pouria:03168] *** End of error message ***
mpirun noticed that process rank 1 with PID 3168 on node pouria exited on signal 8 (Floating point exception).
by the way. I am uploading a section of my project geometry. The purple block shows AMI region.
thank you.
Taghi is offline   Reply With Quote
Old   May 16, 2017, 18:07
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
for your moveDynamicMesh application you should call the following:
moveDynamicMesh -noFunctionObjects -checkAMI
After that, check if your mesh is correct moving.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   May 17, 2017, 04:28
Pouria Taghikhani
Thanks. It worked. But I still have problems with pimplyDyMFoam
Old   May 17, 2017, 06:18
Tobi's Avatar
Tobias Holzmann
Is your AMI moving correctly and are the BC correct? You have a floating point exception (division by zero). Maybe you missed some
value uniform xxx;
in a BC. Sometimes it happen that this causes the problem. However, your information are not sufficient to give any other advice. The only point is, that the solver give up after you solve your pressure equation. You can also try to deactivate the momentum predictor but there are a lot of things that can cause your problem.
Keep foaming,
Tobias Holzmann
Old   June 21, 2017, 08:00
Pouria Taghikhani
Hi again. It took a long time but I think I figured were the problem is. The AMI is too close to Boundaries. Is there any way that I can rotate my propeller without AMI. MRF of SRF?
Old   June 21, 2017, 08:06
Tobi's Avatar
Tobias Holzmann
I think not, but you can use ACMI and directly include the boundary into the moving zone.
Keep foaming,
Tobias Holzmann
moving mesh, pimpledymfoam, propellers
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
