setFields problems
Like Tree5Likes
  • 3 Post By Phicau
  • 1 Post By Phicau
  • 1 Post By yangzhuan
Old   July 11, 2017, 09:47
Default setFields problems
Alice
yangzhuan is on a distinguished road
I just learn openFOAM for a short time. And a problem has been bothering me for a week. Why my setFields is not work. My setFields is that.
defaultFieldValues
volScalarFieldValue alpha.water 0
regions
boxToCell
box (0 0 0) (1.0 0.1 0.1);
fieldValues
volScalarFieldValue alpha.water 1
This case is a channel od dimensions 1.00m*0.10m*0.15m(length, width, height). No matter how to change the boxToCell, there is nothing to change. Only the inlet is water. But i want a half water and the rest is air. I have seen many posts here. But there is still no solution. I really nead help.
Thank you!
yangzhuan is offline   Reply With Quote
Old   July 11, 2017, 09:58
Brian Willis
Dipsomaniac is on a distinguished road
Hi Alice
It will help to show the axes and extent of the domain, so that we know where the origin is relative to the domain. setFields works with respect to the origin, and your defined box may actually be outside of the domain of interest.
Regards,
Brian
Dipsomaniac is offline   Reply With Quote
Old   July 11, 2017, 11:09
Army
Blanche is on a distinguished road
I think it is that. I also want to ask this question.
Blanche is offline   Reply With Quote
Old   July 11, 2017, 11:41
Talking
Alice
Originally Posted by Dipsomaniac View Post
Hi Alice
Regards,
Brian
Thanks a lot,
I marked several special points on the Figer. I don't know where is wrong. I hope you can give me some advice.
Thank you again.
Old   July 11, 2017, 12:23
Brian Willis
can you please run
checkMesh
and post the results?
Old   July 11, 2017, 19:01
Thomas
Tomatenbart is on a distinguished road
What exactly do you want to be covered in water?
Have you changed your mesh after you firstly executed setFields?
Try deleting your alpha.water file in the 0 folder and get a new fresh one in there, so that in the alpha.water file is no water field set and you don't see any 1 and 0. And then execute setFields again.
Sent from my iPhone using CFD Online Forum mobile app
Tomatenbart is offline   Reply With Quote
Old   July 11, 2017, 23:03
Alice
can you please run
checkMesh
Ok, I run the "checkMesh". The result is that,
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 354288
internal faces: 331458
cells: 114291
faces per cell: 6
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 114291
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
in 102 126 ok (non-closed singly connected)
out 459 504 ok (non-closed singly connected)
bimian 18036 18352 ok (non-closed singly connected)
atmosphere 4233 4500 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 -3.55271e-15 -3.55271e-15) (1000 100 150)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-2.341e-17 8.36564e-18 -5.38205e-15) OK.
Max cell openness = 1.50386e-16 OK.
Max aspect ratio = 2.71493 OK.
Minimum face area = 8.70147. Maximum face area = 38.3754. Face area magnitudes OK.
Min volume = 51.1851. Max volume = 154.118. Total volume = 1.5e+07. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 2.8308e-13 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   July 11, 2017, 23:25
Pablo Higuera
Phicau is on a distinguished road
There you go, your overall domain bounding box is (1000 100 150) and you are filling only (1.0 0.1 0.1).
You need to modify blockMeshDict, either changing the coordinates to metres or add "convertToMeters 0.001;" to it.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   July 11, 2017, 23:32
Alice
Best,
Pablo
I use the ICEM to draw the mesh. There is no blockMeshDict. So what should I input in the terminal?
Old   July 11, 2017, 23:35
Pablo Higuera
Then run this utility:
transformPoints -scale '(0.001 0.001 0.001)'
floquation likes this.
Old   July 11, 2017, 23:48
Alice
I have tried. it works. This problem has been bothering me for several days, and finally solved. Thank you for your help. Thank you!
Hope you have a nice day!
Dipsomaniac likes this.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
InterDyMFoam and problem with setFields chris_sev OpenFOAM Running, Solving & CFD 1 March 23, 2009 22:23
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
