Looking for the foam-extend User Guide
Like Tree1Likes
  • 1 Post By wyldckat
Old   August 26, 2017, 02:39
Default Looking for the foam-extend User Guide
Hanye Azimi
ronak is on a distinguished road
Hello Foamers
Is there any User Guide for OpenFOAM foam-extended versions? I'm going to work with OpenFOAM foam-extended-3.0 or foam-extended-3.2 ,or foam-extend-3.1 or foam-extend-4
I'll appreciate you if you help me in finding it.
ronak is offline   Reply With Quote
Old   August 27, 2017, 12:48
Retired Super Moderator
Bruno Santos
Quick answer: The following is also applicable for foam-extend:
Originally Posted by wyldckat View Post
Manuals and Guides:
  • Official OpenFOAM User Guide:
    • The local copy in your OpenFOAM installation can be found by running this command:
      echo $WM_PROJECT_DIR/doc/Guides-a4/UserGuide.pdf
  • Official (but not fully supported) OpenFOAM Programmer's Guide:
    • The local version in your OpenFOAM installation can be found by running this command (although it's no present in OpenFOAM 4.0 and newer versions, but should still be in OpenFOAM+):
      echo $WM_PROJECT_DIR/doc/Guides-a4/ProgrammersGuide.pdf
  • Community created wiki pages, aimed to complement the official guides: http://openfoamwiki.net/index.php/OpenFOAM_guide
CFD- likes this.
foam-extend-3.1, foam-extend-4.0
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 5 June 22, 2019 02:56
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
