September 14, 2017, 08:26 |
dambreak tutorials
Surrey
Rep Power: 8 |
Hi I am trying to follow the dambreak tutorial and I was running the setfields command. but when I check that in the paraview the box has not generated but alpha.water file was updated with the value 0 and 1 for 2268 entries. setfields.JPG
alpha.water.jpg |
September 17, 2017, 14:22 |
Tobias Holzmann
Rep Power: 51 |
This is a paraview reader problem. I have similar problems while using Paraview 5.4.0-RC2. However, the calculation can be run and the first time step is read as it should. I had no time to check the source of the problem. So don't care about it. Maybe paraFoam solves the problem.
Keep foaming, Tobias Holzmann |
September 18, 2017, 02:58 |
Rep Power: 8 |
Tested the paraFoam command on the same Windows porting distribution and the reader problem at time 0 persist. However I was able to run and visualize the case without any other issues. Like Tobi said, you should not worry.
September 18, 2017, 22:13 |
Surrey
Rep Power: 8 |
thank you very much.
dambreak tutorial's weird velocity field. | sharonyue | OpenFOAM | 8 | October 18, 2016 14:57 |
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx | Jaro | OpenFOAM Running, Solving & CFD | 8 | March 16, 2016 07:27 |
OpenFOAM video tutorials | RAUL | OpenFOAM Announcements from Other Sources | 9 | August 27, 2014 07:00 |
[DesignModeler] Help with tutorials | jony | ANSYS Meshing & Geometry | 0 | May 14, 2013 00:41 |
Install tutorials | jonlemur | OpenFOAM Installation | 4 | August 8, 2007 14:15 |
