I encounter an error when I run pisoFoam after creatPatch . |
September 14, 2017, 09:17 |
ruan xinjian
error as follows ,hope some one could help me.
Starting time loop fieldAverage fieldAverage1: Starting averaging at time 0 forces forces: Not including porosity effects forceCoeffs forces: Not including porosity effects Time = 2e-06 Courant Number mean: 0.00522252 max: 0.592182 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0928333, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0545486, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0513407, No Iterations 2 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::cyclicAMIGAMGInterface::neighbPatchID() const at ??:? #4 Foam::cyclicAMIGAMGInterface::internalFieldTransfe r(Foam::UPstream::commsTypes, Foam::UList<long> const&) const at ??:? #5 Foam::GAMGAgglomeration::agglomerateLduAddressing( long) at ??:? #6 Foam:airGAMGAgglomeration::agglomerate(Foam::ldu Mesh const&, Foam::Field<double> const&) at ??:? #7 Foam::faceAreaPairGAMGAgglomeration::faceAreaPairG AMGAgglomeration(Foam::lduMesh const&, Foam::dictionary const&) at ??:? #8 Foam::GAMGAgglomeration::addlduMeshConstructorToTa ble<Foam::faceAreaPairGAMGAgglomeration>::New(Foam ::lduMesh const&, Foam::dictionary const&) at ??:? #9 Foam::GAMGAgglomeration::New(Foam::lduMesh const&, Foam::dictionary const&) at ??:? #10 Foam::GAMGAgglomeration::New(Foam::lduMatrix const&, Foam::dictionary const&) at ??:? #11 Foam::GAMGSolver::GAMGSolver(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:? #12 Foam::lduMatrix::solver::addsymMatrixConstructorTo Table<Foam::GAMGSolver>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:? #13 Foam::lduMatrix::solver::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:? #14 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #15 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #16 ? at ??:? #17 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #18 ? at ??:? Segmentation fault (core dumped) |
September 15, 2017, 03:37 |
Rep Power: 8 |
Hi crazy flow,
is the mesh OK after creating patch? Personally this is the first time I see such error but if you could upload the whole case, or at least the dictionaries, more experienced users might be able to help. |
error creatpatch pisofoam |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Cycling a transient run | Chetan Mistry | Phoenics | 0 | March 3, 2004 09:50 |
