periodic (cyclic) boundary - fluent3DMeshToFoam |
October 3, 2017, 18:42 |
cyln
Rep Power: 9 |
My computational domain has a shape of slice of a cylinder. I have generated my mesh on this domain using ICEM. Two sides are defined as periodic boundaries. However, when I use fluent3DMeshToFoam to convert the mesh in OpenFOAM, the software faces issues due to the periodic (cyclic) boundary. A suggested alternative way is to define these periodic boundaries, lets say as symmetry boundaries, then convert the mesh using fluent3DmeshToFoam. Then you use createPatch funtion ( via createPatchDict file) to convert your symmetry boundaries to cyclic boundaries. I performed these steps. I modified createPatchDict file as suggested. When I run createPatch, at the beginning, it works fine but I get the following error at the end. > FOAM FATAL ERROR: For patch SIDE11 there are 159185 face centres, for the neighbour patch SIDE22 there are 160271 From function void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 156. FOAM exiting Obviously, the number of face centres are different on each side. Is there any way to solve this problem? I would appreciate any suggestion Cheers |
October 17, 2017, 02:59 |
Rep Power: 9 |
maybe there is something wrong with your createPatchDict
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
