Upwind Gradient Not Recognizing surfaceScalarField
Old   May 11, 2016, 13:15
Default Upwind Gradient Not Recognizing surfaceScalarField
Majid Haghshenas
MajidHagh is on a distinguished road
Hi all,
I'm trying to use first order upwind gradient that depends on a user defined surfaceScalarField for the upwinding direction. But I have problem where the solver does not recognize my user defined surfaceScalarField, "SSF", when I select the discretization scheme in the fvSchemes file. For instance, when I want to take gradient of some volScalarField, "psi", in my solver, I put
grad(psi) Gauss upwind SSF;
in fvSchemes.
Where, as I mentioned above, "SSF" is my user defined field. If its relevant, It was initialized using:
surfaceScalarField SSF
        IOobject
            "SSF",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
         fvc::interpolate(alpha1)
When I try to run the solver, it doesn't recognize or even see that "SSF" exists as a surfaceScalarField. I receive the following error at runtime:
 request for surfaceScalarField SSF from objectRegistry region0 failed
    available objects of type surfaceScalarField are
5
rhoPhi
ghf
phi
nVecf
nHatf
I want to use my SSF surfaceScalarField but I can not.
Anyone knows how to define the SSF that would be recognized in the fvSchemes?
MajidHagh is offline   Reply With Quote
Old   May 13, 2016, 10:43
Default Problem Solved
Majid Haghshenas
Problem is solved.
Old   October 30, 2019, 11:58
Default What was the solution?
Arpit
foam is on a distinguished road
Hey, I'm running into the exact same issue. How did you fix it?
foam is offline   Reply With Quote
bug, error, upwind gradient
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Implementation of 2nd order upwind scheme jaason OpenFOAM Running, Solving & CFD 4 February 6, 2015 17:40
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
