--> FOAM FATAL ERROR: Operator + is undefined for oriented and unoriented types |
January 17, 2018, 02:39 |
Rep Power: 11 |
Hi guys,
Maybe someone know what this error is about ? Code:
--> FOAM FATAL ERROR: Operator + is undefined for oriented and unoriented types I'm using PimpleDymFoam for passive scalar transport problem. |
February 22, 2018, 17:33 |
Hendrik
Rep Power: 9 |
Hi there,
did you find the cause for this error? I'm getting the same but for pisoFoam and a normally already proven case. Does it have to do something with the mesh maybe? |
February 25, 2018, 09:52 |
oz
I have the same problem. this problem occurs for piso based solvers not for simpleFoam and although it can solve U, it gives an error calculating p. Interestingly, while ı got this error with OpenFOAM 1612, OpenFOAM 5.0 doesnt give any error and start to calculate p. Is there anyone having an idea? |
February 25, 2018, 10:21 |
Hendrik
Rep Power: 9 |
Actually I found the issue causing the error in my case. I simply forgot to change the time scheme in fvSchemes from "steadyState" to a transient one ("backward"). As pisoFoam is a transient solver it obviously crashed.
February 25, 2018, 10:35 |
oz
Thnak you for reply. I forgot to change ddt too.
