Unusual velocity profile with pentahedra cells
Old   March 19, 2018, 03:50
Default Unusual velocity profile with pentahedra cells
tdof is on a distinguished road
I'm doing some studies on an extrusion head and created the mesh mostly via rotation and extrusion in Hypermesh which resulted in pentahedra cells along the middle axis of a J-bend right after the inlet. The odd thing is that the velocity in these pentahedra cells is a lot lower than in their surrounding cells, but it continues to converge to its surrounding velocity with increasing runtime. I remembered that I saw a similar behaviour when doing first examples in OpenFOAM with a 5 degree straight pipe section with pentahedra along the middle axis and hexahedra elsewhere. My guess is that OpenFOAM has some sort of problem with pentahedra cells, but I can't think of a reason why. Is it the cell size? This behaviour is independent of fluid property and I've provided a link to the case (without mesh since I can't publish it), but there are a few pictures. Does anybody have an idea what's happening and how to prevent it, apart from using another mesh structure?
https://1drv.ms/f/s!AqGKZzn3ghyumBowygR94yGGdqlz
tdof is offline   Reply With Quote
Old   March 19, 2018, 09:45
Saideep
Saideep is on a distinguished road
I did observe this sort of behavior in the interFoam solver for a complex mesh of mine but I realized it was due to numerical dispersion. I changed the solver a bit to solve this issue.
Further few things to be kept in mind are the "goodness of your mesh": maybe there is a better mesh than the one you have [try checking with "checkMesh" and see for any mesh fails]. If everything was fine, atleast the skewness shall fail which is good to know.
Later, if the mesh is already good enough, check for the schemes you use as "Gauss linear" is good for orthogonal meshes. Also, try setting your Courants number or ideally your time step size less initially.
Hope this helps!!
Saideep is offline   Reply With Quote
Old   March 19, 2018, 10:14
Hi Saideep,
how did you change the solver exactly? Were the failing cells also pentahedra?
Here's the checkMesh output:
Mesh stats
    faces:            708555
    internal faces:   668055
    cells:            229950
    faces per cell:   5.98656
    boundary patches: 4
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     226890
    prisms:        3000
    wedges:        0
    pyramids:      30
    tet wedges:    0
    tetrahedra:    30
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    fixedWalls          23820    24646    ok (non-closed singly connected)
    sym                 15330    16129    ok (non-closed singly connected)
    inlet               1050     1086     ok (non-closed singly connected)
    outlet              300      341      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 -0.459 -0.0749979) (0.028 0.009 0.028)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (2.33654e-15 -4.29265e-18 -1.15824e-16) OK.
    Max cell openness = 1.01507e-15 OK.
    Max aspect ratio = 142.191 OK.
    Minimum face area = 1.09322e-08. Maximum face area = 6.8249e-06.  Face area magnitudes OK.
    Min volume = 1.83692e-12. Max volume = 3.14243e-09.  Total volume = 0.000141659.  Cell volumes OK.
    Mesh non-orthogonality Max: 56.3886 average: 9.28842
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.42746 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
There definitely is a better mesh, this problem probably stems from the mesh creation method I used. I can't seem to get it running with a tetrahedra mesh using Hypermesh as it can't handle the geometry all too well. It always creates a few very small tetras that I can't get rid of no matter how I alter the settings, and it doesn't support merging tetras to polyhedras.
Have a look at the system folder in the link I posted.
fvschemes:
ddtSchemes
    default         Euler;
    gradSchemes
        default leastSquares;
        grad(DU) leastSquares;
        snGradCorr(DU) leastSquares;
        grad(sigma) leastSquares;
divSchemes
    default                  Gauss linear;
    div(phi,U)               Gauss upwind;
    div(phi,sigma)           Gauss upwind;
    div(phi,sigmafirst)           Gauss upwind;
    div(phi,sigmasecond)           Gauss upwind;
    div(phi,sigmathird)           Gauss upwind;
    div(phi,sigmafourth)           Gauss upwind;
    div(phi,sigmafifth)           Gauss upwind;
	div(phi,sigmasixth)           Gauss upwind;
	div(phi,sigmaseventh)           Gauss upwind;
    div(tau)                 Gauss linear;
    div(taufirst)                 Gauss linear;
    div(tausecond)                 Gauss linear;
    div(tauthird)                 Gauss linear;
    div(taufourth)                 Gauss linear;
	div(taufifth)                 Gauss linear;
    div(tausixth)                 Gauss linear;
    div(tauseventh)                 Gauss linear;
laplacianSchemes
    default                      Gauss linear corrected;
    laplacian(etaPEff,U)         Gauss linear corrected;
    laplacian(etaPEff+etaS,U)    Gauss linear corrected;
    laplacian((1|A(U)),p)        Gauss linear corrected;
interpolationSchemes
    default           linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         corrected;
Gauss linear isn't recommended at least for gradSchemes, see "Gauss linear" gradient makes OpenFOAM zeroth-order accurate on unstructured meshes
The Courant number is not that relevant for the viscoelastic simulations at hand (I forgot to mention those) as it won't reach critical regions since other stability criteria hit first. The time step is limited to 1e-3 and starts at 1e-5.
Old   March 27, 2018, 05:22
Well, I've found the error. I've made a stupid mistake defining the viscoelastic properties and with the right definitions, it works as intended.
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
InterFoam - Validation for velocity profile in simple channel me.ouda OpenFOAM Running, Solving & CFD 0 October 19, 2015 06:42
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 15:31
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
