May 17, 2018, 22:11 |
Nut generating a floating point exception
Roberto Vázquez
Good evening,
I'm pretty new to OpenFOAM and CFD in general, so this may be a dumb question. I'm trying to simulate flow in a pipe with chtMultiRegionSimpleFoam, but when I run my case, I get the following message: #0 Foam::error:: printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam:: operator/(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) at ??:? #5 Foam::CompressibleTurbulenceModel<Foam::fluidTherm o>::nu(int) const at ??:? #6 Foam::nutkWallFunctionFvPatchScalarField::calcNut( ) const at ??:? #7 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:? #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() at ??:? #9 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:? #10 ? at ??:? #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? at ??:?Floating point exception (core dumped) I've read other posts with similar errors, with replies saying that most likely k and epsilon have initial values of zero. Mine are very small, around 3e-6, but definitely not zero. I don't really know what to do when I don't get a FOAM fatal error, so any help would be appreciated . Thank you all in advance! Last edited by robvazdom; May 17, 2018 at 22:13. Reason: smileys in my text |
June 19, 2018, 17:24 |
Raunak Bardia
Rep Power: 11 |
I am facing the same issue while trying to run "reactingFoam". I understand that the error is being generated from the calcNut() function called from the boundary condition "nutkwallfunction".
Here is that function: Code:
tmp<scalarField> nutkWallFunctionFvPatchScalarField::calcNut() const { const label patchi = patch().index(); const turbulenceModel& turbModel = db().lookupObject<turbulenceModel> ( IOobject::groupName ( turbulenceModel::propertiesName, internalField().group() ) ); const scalarField& y = turbModel.y()[patchi]; const tmp<volScalarField> tk = turbModel.k(); const volScalarField& k = tk(); const tmp<scalarField> tnuw = turbModel.nu(patchi); const scalarField& nuw = tnuw(); const scalar Cmu25 = pow025(Cmu_); tmp<scalarField> tnutw(new scalarField(patch().size(), 0.0)); scalarField& nutw = tnutw.ref(); forAll(nutw, facei) { label celli = patch().faceCells()[facei]; scalar yPlus = Cmu25*y[facei]*sqrt(k[celli])/nuw[facei]; if (yPlus > yPlusLam_) { nutw[facei] = nuw[facei]*(yPlus*kappa_/log(E_*yPlus) - 1.0); } } return tnutw; } Code:
//- Return the laminar viscosity on patchi virtual tmp<scalarField> nu(const label patchi) const { return this->transport_.mu(patchi)/this->rho_.boundaryField()[patchi]; } Help from the more experienced FOAMers will be really useful. Last edited by raunakbardia; June 19, 2018 at 17:52. Reason: Identifying the Code component separately. |
July 25, 2020, 07:34 |
BTmaxxx
Rep Power: 6 |
Did you find a solution to this? I have run into a similar problem. |
chtmultiregionsimplefoam, floating point error, nut, openfoam |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
