NASA rotor 37
Like Tree4Likes
Old   January 18, 2019, 03:34
Ersin
ersoflow is on a distinguished road
Originally Posted by tjuAeron View Post
hi Ersin,
Currently I'm doing the same thing with foam-extend-4.0 but with little progress.
What do you mean by "The results seemed not really bad"? What about pressure ratio and isentropic efficiency you got?
And why you set p::inlet:0 1.4e5 pa rather than 101325 pa in experiment? And so as the Temperature condition of inlet.
Thanks for you sharing
Hi tjuAeron,
The boundary conditions that I used were nearly same as in the tutorial bentRotorStator because that was my first run with the solver steadyCompressibleMRFFoam and also in foam-extend.
The resultant fileds were not true for real rotor 37 ofc.
I am not experienced in turbomachinery but at least those are some results () with residuals less than 10^-3.
I am having a break on this project due to other projects.
Ersin
ersoflow is offline   Reply With Quote
nasa 67, openfoam, rhosimplefoam, rotor37
NASA Format Stone CFX 3 August 11, 2021 03:16
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
