simple question about OpenFoam matrix class
Old   August 8, 2018, 09:37
Default simple question about OpenFoam matrix class
TurbJet is on a distinguished road
I have one simple question about OpenFoam matrix class.
In it's definition, the function 'allocate' says:
void Foam::Matrix<Form, Type>::allocate()
    if (n_ && m_)
        v_ = new Type*[n_];
        v_[0] = new Type[n_*m_];
        for (register label i=1; i<n_; i++)
            v_[i] = v_[i-1] + m_;
What baffles me is that since v_ is a pointer to a pointer, it supposes to be a 2D array. However, what about this part:
? It seems only v_[0] saves the entire matrix, namely the matrix is stored in a 1D-form. But why it still do this :
v_ = new Type*[n_];
Why not doing something like:
v_ = new Type * [n_];
for(i=0; i<n_;++i)
    v_[i] = new Type [m_];
Thanks ahead !
TurbJet is offline   Reply With Quote
Old   August 9, 2018, 02:47
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
My guess is that two memory allocations
v_ = new Type*[n_];
were deemed more efficient than doing n+1 allocations
for(i=0; i<n_;++i)
The way it is implemented
    if (n_ && m_)
        v_ = new Type*[n_];
you get pretty much the look&feel of a 2D array.
GerhardHolzinger is offline   Reply With Quote
Old   August 10, 2018, 20:53
v_ = new Type*[n_];
for(i=0; i<n_;++i)
    if (n_ && m_)
        v_ = new Type*[n_];
I still don't get it. With this one
doesn't it mean all the elements will be saved in v[0][i] ? If so, why doesn't it just declare a 1D array to save the entire matrix?
matrix, openfoam
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
How to rewrite a standard OpenFOAM solver as a C++ class cfbaptista OpenFOAM Programming & Development 7 March 23, 2016 04:50
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
