September 28, 2018, 12:57 |
Running aplications in parallel
Nicolás Merchán
Hello
I'm trying to run a case in parallel but I keep geting the same error over and over again. I'm runnig the case in a cluster with 9 processors and use the following comand mpirun -np 9 interFoam -parallel >log Please if someone can help me find the mistake I would be grateful. MPI_ABORT was invoked on rank 2 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- 0] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [0] in file db/functionObjects/functionObject/functionObject.C at line 100. [0] FOAM parallel run exiting [0] . [1] FOAM parallel run exiting [1] [2] FOAM parallel run exiting [2] [nicolas:13699] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [nicolas:13699] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel | sbence | OpenFOAM Installation | 10 | December 5, 2018 08:44 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
