FOAM FATAL ERROR:Operator + is undefined for unoriented and oriented types |
Ningyi Li
Rep Power: 8 ![]() |
Hi, FOAMERS,
I have met one error when I run my programming. In my programming, I redefined the way to calculate rho and phi in the following codes: rho1 = theta_Psi * p0; phi1 = fvc::interpolate(rho1) * fvc::interpolate(U) & mesh.Sf(); Then I used the rho1 and phi1 in my equation file: fvScalarMatrix theaEqn ( fvm::ddt(rho1, theta1) + mvConvection->fvmDiv(phi1, theta1) - fvm::laplacian(turbulence->muEff(), theta1) == theta_1RR ); And I modified discrete format in the sytem/fvScheme file: ddtSchemes { // default Euler; default backward; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi1,U) Gauss limitedLinearV 1; div(phi,Yi_h) Gauss limitedLinear 1; div(phi1,Yi_h) Gauss limitedLinear 1; div(phi,K) Gauss limitedLinear 1; div(phid,p) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; // div(phi1,epsilon) Gauss limitedLinear 1; div(phi,k) Gauss limitedLinear 1; // div(phi1,k) Gauss limitedLinear 1; However when I run my programming in the counterFlowFlame2D case, there is one error like this: --> FOAM FATAL ERROR: Operator + is undefined for unoriented and oriented types From function Foam: ![]() ![]() ![]() ![]() in file orientedType/orientedType.C at line 461. FOAM aborting #0 Foam::error: ![]() #1 Foam::error::abort() at ??:? #2 Foam: ![]() ![]() ![]() #3 void Foam::add<double, double, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::type OfSum<double, double>::type, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:? Could someone can help me to explain the meaning of this error and how to solve it? Thank you so much. Ning |
Rep Power: 10 ![]() |
Dear all,
I understand that this is an old thread but I faced a similar issue recently. While I don't understand the real meaning of this error, I found out that it occurred when trying to add the face flux (defined below) to some other quantity. Code:
surfaceScalarField phi(Uf & mesh.Sf()); Code:
phi.setOriented(false); Best, USV |
--> FOAM FATAL ERROR: Operator + is undefined for oriented and unoriented types | gamemakerh | OpenFOAM | 4 | February 25, 2018 10:35 |
