[Sponsors] | |||||
Inlet and outlet on the same patch in openfoam? |
Rep Power: 9 ![]() |
Hello community,
I am working on a small project and wants to use a patch for both inlet of gas and outlet of liquid. I am using OFv 1806. Please is there a way I can do this with groovyBc or any other way? Thank you |
#2 | |
Geir Karlsen
Rep Power: 15 ![]() |
//For alpha
myPatch
type inletOutlet;
inletValue uniform 0;
value uniform 0;
//For U
myPatch
type pressureInletOutletVelocity;
value uniform (0 0 0);
For p_rgh
outlet
type prghTotalPressure;
p0 uniform 0;
value uniform 0;
Thank you very much @gkarlsen
That looks OK but how will that work for an eulerian simulation where different alphas are defined for both gas and liquid? For instance, I want 'myPatch' to be a gas inlet and a liquid outlet So for alpha.gas, can i write mypatch { Type fixedvalue; value uniform 1; } And alpha.liquid, mypatch { Type fixedvalue; value uniform 0; } Can this out? Will liquid be aloud out of this patch? Thank you |
#4 | |
Geir Karlsen
Use InletOutlet as stated above, not fixedvalue. You set the parameter inletValue to whatever value you would like when there is flow in to your domain from the patch. Alpha for discharge from the domain will be according to whatever local conditions are present at the boundary (liquid if there is liquid on the inside, gas if there is gas on the inside and so on). |
Alright, that's clear, thank you very much.
But one more question, how do I specify the velocity of the gas at the patch using pressureInletOutletVelocity? Thank you |
Geir Karlsen
You don't . This BC automatically calculates velocity based on pressure. If you need to set a given velocity you have to use something else
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 05:57 |
| mapField error | rvl565 | OpenFOAM Pre-Processing | 1 | September 6, 2018 17:13 |
| outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 07:56 |
| Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
| ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
