Cyclic sector, turbine stage, simpleFoam, MFR, |
February 23, 2019, 09:52 |
Ivan
Rep Power: 13 |
Hello friends,
I would like to ask you about using of some stady rotor/stator domain. I would like to calculate radial turbine stage for turbocharger. I think that I can start with tutorial/incomptessible/pimpleFoam/impeller and with using of MRFsetup in the constant domain. I want to use the simpleFoam solver and than to go to the rhoSimpleFoam with cycling symmetry. Please do you thing that there is possibility to modify this tutoruial with cyclic symmetry sector and use it with steady solver ? In the attachement, there is the modified tutorial from openfoam by cfddirect V6. Thank you and regards, Ivan |
How to setup cyclic BCs in simpleFOAM | hhuang84 | OpenFOAM Running, Solving & CFD | 14 | December 8, 2016 11:39 |
simpleFoam + cyclic pipe = unstable? | RodriguezFatz | OpenFOAM Running, Solving & CFD | 9 | December 1, 2014 05:28 |
Possible createPatch/createBaffles bug? | simpomann | OpenFOAM Bugs | 2 | July 15, 2014 07:07 |
fully developed channel with cyclic using simplefoam | ArathoN | OpenFOAM Running, Solving & CFD | 4 | February 21, 2014 09:53 |
simpleFoam with cyclic BCs | Ria | OpenFOAM | 4 | October 21, 2013 09:28 |
