Having serious difficulties with 2D airfoil Simulation |
April 21, 2019, 05:19 |
Os
Rep Power: 8 |
I am making a 2D airfoil simulation using SIMPLEfOAM AND PIMPLEFOAM AND at the moment i am following the wing motion tutorial . i have created the Geometry and mesh using Gambit and then imported it to OpenFoam and Also I am using the same Turbulence Model KOmegaSST like in the Wing Motion tutorial. When i run my simulation for AOA=0Degree Using simpleFoam the Solution Converges Very Well . but When i use the same mesh and the same boundary conditions with Pimple Foam the Solution is Instable and guives Horrible values . even when i made adjustable timestep and limiting Courant Number to 0.9 the solution is still instable . Can you Please Tell me Whats the Problem with this .!! |
May 20, 2019, 16:37 |
Klaus
Rep Power: 22 |
Hello Losiola,
please provide your controlDict settings as a basis for feedback. Please have a look at this example: https://www.hpc.ntnu.no/display/hpc/...l+Calculations At first, the authors solve the case with simpleFoam and copy the resulting fields to their pimpleFoam case setup using mapFields which can improve the stability during the first few pimpleFoam iterations. Also, compare deltaT with the example setup, I assume yours is higher. Klaus |
Airfoil 2D cfd simulation | Cocorito90 | OpenFOAM Running, Solving & CFD | 14 | December 19, 2016 03:43 |
airfoil 2D simulation: position of lift force on the airfoil | Koenieboy | Main CFD Forum | 2 | March 13, 2012 06:44 |
Airfoil simulation using moving wall | Alejandro | Fidelity CFD | 9 | November 4, 2008 02:00 |
NO STAGNATION POINT FOR AIRFOIL SIMULATION | Rif | Main CFD Forum | 6 | February 4, 2008 07:33 |
Compressible transonic airfoil RAE2822 simulation | Stefano | Siemens | 9 | June 21, 2006 10:47 |
