OpenFOAM - cyclicAMI Pressure drop result variation |
May 31, 2019, 02:47 |
Vishnu
Rep Power: 6 |
Hi all,
I am facing some irregularities in my result of pressure drop. Actually I have 5 fluid domains - inlet pipe,inlet tank,core(porous medium),outlet tank,outlet pipe. Pressure drop in outlet tank should be lower than inlet tank. Problem is the pressure drop is higher in outlet tank. Pressure drop calculated between inlet tank entry pressure to core inlet pressure i.e.inlet tank pressure . As viceversa for outlet tank pressure.. core out pressure to outlet tank out pressure. But my fine mesh quality and mesh size also good. Iam using cyclicAMI noOrdering transform for this case. Is this any problem with assigning of cyclicAMI boundary conditions in ( U,p,T,k,E,nut) ? May i know why this problem occurs????? Thank you in advance, Vishsel. |
Fluent cyclone pressure drop | mkal | FLUENT | 1 | February 20, 2020 00:55 |
cyclicAMI - kOmegaSST - divergence issue | cyln | OpenFOAM Running, Solving & CFD | 1 | October 5, 2018 10:06 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 11:59 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
