Courant Number Error while using IcoFoam Solver
Old   July 16, 2019, 16:49
Default Courant Number Error while using IcoFoam Solver
Pratyush Kumar
PRATBHARAT is on a distinguished road
Hi, I developed the solver using icoFoam with temperature gradient for the flow over multiple spheres. While I am running the test case. I am getting the following error/
Time = 1.1e-06
Courant Number mean: 0.0312314 max: 105.509
smoothSolver: Solving for Ux, Initial residual = 0.354868, Final residual = 1.0188e+222, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.346559, Final residual = 6.00719e+221, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.455163, Final residual = 6.6173e+221, No Iterations 1000
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/cfdlab/OpenFOAM/cfdlab-3.0.1/platforms/linux64GccDPInt64Opt/bin/my_icoFoam"
#7 ? in "/home/cfdlab/OpenFOAM/cfdlab-3.0.1/platforms/linux64GccDPInt64Opt/bin/my_icoFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? in "/home/cfdlab/OpenFOAM/cfdlab-3.0.1/platforms/linux64GccDPInt64Opt/bin/my_icoFoam"
Floating point exception (core dumped)
Kindly solve my issue. I am attaching the solver and test case too.
Thanks in advance.
PRATBHARAT is offline   Reply With Quote
Old   July 18, 2019, 08:09
Default check your mesh
sagar saroha
sagar_saroha is on a distinguished road
Hi
The 'floating-point exception' error indicates a problem with mesh.
Run the following command and share the output from the log file:
checkMesh > meshReport.log
sagar_saroha is offline   Reply With Quote
Old   July 21, 2019, 15:51
Pratyush Kumar
Hi sagar_saroha
Thanks for replying...
Here, I am attaching the checkMesh report. Please, look in to it.
Old   July 21, 2019, 18:05
CFD USER
CFD_10 is on a distinguished road
What about your time step deltaT?
CFD_10 is offline   Reply With Quote
Old   July 22, 2019, 03:24
hxaxtma is on a distinguished road
If you need help, please give us more information about your case. Next, provide your BCs for U and p. Pretty sure that your BCs are set wrong.
hxaxtma is offline   Reply With Quote
Old   July 22, 2019, 03:54
Pratyush Kumar
object controlDict;
application my_icoFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 0.01;
deltaT 1e-7;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 10;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 1.0;
maxDeltaT 0.1;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.0002 0 0);
outlet
type zeroGradient;
value uniform (0 0 0);
side_walls
type fixedValue;
spheres
type fixedValue;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
side_walls
type zeroGradient;
spheres
type zeroGradient;
Kindly, again look in to the controlDict and BCs.
Old   July 22, 2019, 18:11
anon_q is on a distinguished road
Could you just share your case?
anon_q is offline   Reply With Quote
Old   August 2, 2019, 02:13
WJ
misospider is on a distinguished road
This is most likely due to mesh and time step issue.
BCs are look ok.
Reduce time step and maxCo to less than 0.7, recommeding 0.5.
And save each time step until crash, check flow what is going wrong, especially at high Co>1.
If your setting are ok, this is problem of mesh quality, as you can see there are converted meshes (non-orthg.), if you can you need to mak mesh without that.
misospider is offline   Reply With Quote
Old   August 2, 2019, 03:01
Default Reduce mesh non-orthogonality
sagar saroha
Originally Posted by PRATBHARAT View Post
Hi sagar_saroha
Hi Pratyush
Please note that mesh non-orthogonality is high (>75) in 34 cases- please locate and try to correct these. [as also suggested by WJ].
Old   August 5, 2019, 15:43
Pratyush Kumar
Hi sagar_saroha ,
I am new in CFD. Can you explain how can I correct these non orthogonality?
Old   August 6, 2019, 06:07
Default Revisit the meshing stage and check near sphere regions
  #11
sagar saroha
Hi Pratyush
Non-orthogonality is related to the angle of intersection of mesh lines. Using mesh elements of larger size (or using less element count) may lead to high non-orthogonality in case of unstructured grids.
Most of the commercial solvers have an 'inbuilt-mesh check' feature which highlights and suggests ways to repair mesh elements with non-orthogonality.
Otherwise, a crude way is using the hit-and-trial method by reducing element size in the suspected zones of bad quality mesh. A rough guess would be 'near sphere geometry' zone(s).
I would be able to comment better after seeing mesh snap-shot.
Old   August 6, 2019, 08:46
Pratyush Kumar
https://drive.google.com/file/d/1Wjf...ew?usp=sharing
Here I am attaching my mesh file. Kindly look in to it and solve my problem.
Courant Number waseeqsiddiqui FLUENT 3 December 27, 2018 10:43
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 22:29
Weird AMI Courant Number Vyssion OpenFOAM Running, Solving & CFD 3 April 13, 2016 02:31
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
