Solving multiphase one way coupled problem in SU2
Old   August 2, 2019, 00:08
Default Solving multiphase one way coupled problem in SU2
Bidesh Sengupta
BSengupta is on a distinguished road
I wish to solve a multi-phase(air-water droplet) one way coupled problem(collection efficiency around airfoil) in SU2. The steps involving my problem are:
1. Solving the flow domain considering air as only fluid around airfoil with NSF.
2. Taking the solution(velocities) of air flow as initial condition, solving the flow domain with droplet with Euler Equation (without pressure) with some source term.
Let the velocity of air be Va (which is position dependent) and remains constant during droplet flow calculation.
Now the source term of the droplet equation involves some drag term which is a function of (Va-Vd). Vd being the droplet velocity.
Now I am unable to figure out the following:
1. How can I initialize the air solution for droplet flow calculation?
2. How can I instruct SU2 that the air velocity as Va, because it will be needed in the drag calculation.
3. Can I solve Euler equation in SU2 with involving pressure.
4. How can I add source term.
Thank you so much.
BSengupta is offline   Reply With Quote
Old   August 26, 2019, 11:13
Post Chalmer university report 2010
Andrew Smith
Andrew_Sm is on a distinguished road
Chalmer University report : 2010
Check these out,
http://web.student.chalmers.se/group...SlidesOFW5.pdf
Andrew_Sm is offline   Reply With Quote
Old   August 26, 2019, 19:52
Bidesh Sengupta
Thank you.
Old   August 31, 2019, 00:26
Thumbs up Icing in OpenFOAM
Andrew Smith
Welcome! BSengupta,
Are you working on ICING ?
if I am not wrong, Chalmers uploaded OpenFOAM codes online which tackles all these issues. Check those it will be useful for your work
Old   September 1, 2019, 11:31
Default Multiphase
lm0x is on a distinguished road
How can I use MPPIC with MFR?
lm0x is offline   Reply With Quote
Old   September 1, 2019, 19:59
Bidesh Sengupta
Originally Posted by Andrew_Sm View Post
Welcome! BSengupta,
Yes I am in Icing. Thanks a lot.
One more thing I would like to know do you have any idea how to implement AMI in dbnsTurbFoam. I tried to implement in openFoam from pimpleDymFoam but I found it difficult. Can you give any clue about it?
If possible can you kindly provide the link of their code.
Thanks,
Bidesh
coding style, su2
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
