lagrange solver
Old   January 8, 2014, 02:05
Default lagrange solver
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I have a question to you all due to the lagrange solver.
My new Project is a hydrocyclone with particel Simulation.
Last year I simulated a hydrocyclone (just flow field) and now I have a new cyclone design and want to simulate the flow field and particel tracking in the cyclone.
First question
- Particels are nonreacting, so is it possible to create the flow field first ( simpleFoam ) and after it using icoUncoupledParcelsFoam for the particel tracking ?
Second question
- Is there any hints of the complex particel Settings that I have to make in the propertie file or do I have to check out the code for resolving the variables like SOI ... etc. Furthermore I think it is possible to inject a cloud of particels with different Diameters.
Third question
- If I use icoUncoupledKinematicParcelFoam the particels are not only moving on the streamlines, aren īt they?
Fourth question
- at the beginning I want to inject some particels into the 2D pitzDaily tutorial. Therefor I solved the flow field with simpleFoam and injected particels with the icoUncoupledKinematicParcelFoam. The Output of the solver seems okay and particels are injected but I can not see any particel with apraview. The lagrangian field is loaded but there are no particesl?
Thanks in advance and some good hints.
Tobi
Tobi is offline   Reply With Quote
Old   July 2, 2014, 04:20
Adil T
idnis is on a distinguished road
Hi Tobi,
I'm sorry I don't have responses for your questions but I think you have the answer I am looking for ^^
Please could you tell me how did you to combine simpleFoam and icoUncoupledKinematicParcelFoam ?
I need to modelize water droplets in gas, I have already created the gas flow with simpleFoam but I don't know how to inject it in "icoUncoupled[...]Foam", I would like to edit the existing tutorial hopperInitialState but I am really lost as I am a new OpenFoam user.
Thanks in advance for your response
idnis is offline   Reply With Quote
Old   June 9, 2017, 08:46
Sebastian Trunk
sisetrun is on a distinguished road
Hey Tobi,
It's been a while since your post, but I am currently working on the same problem.
With your experience, can you now answer your questions from the post?
Thanks for your Info
Cheers
sisetrun is offline   Reply With Quote
Old   October 16, 2019, 05:01
johanning is on a distinguished road
Hi
have you found a solution to your problem yet? I converted everything to IcoUncoupled but don't get Lagrange fields and don't know why. If you have results, could you upload your files?
Regards
Johanning
Originally Posted by Tobi View Post
Hi all,
First question
Second question
Third question
Fourth question
Tobi
johanning is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
