cannot be called for a calculatedFvPatchField |
December 11, 2019, 10:40 |
Russell
Hi all,
Recently i have a problem when i use the solver rhoSimpleFoam, i got the following error: --> FOAM FATAL ERROR: cannot be called for a calculatedFvPatchField on patch wall of field e in file "/home/zhang/OpenFOAM/zhang-7/run/CO2/AO1/0/e" You are probably trying to solve for a field with a default boundary condition. From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 188. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::calculatedFvPatchField<double>::gradientInte rnalCoeffs() const at ??:? #3 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/zhang/OpenFOAM/zhang-7/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" #7 ? in "/home/zhang/OpenFOAM/zhang-7/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/home/zhang/OpenFOAM/zhang-7/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" And here is my h file: dimensions [0 2 -2 0 0 0 0]; internalField uniform 354690; boundaryField { top { type zeroGradient; } bottom { type zeroGradient; } middle { type zeroGradient; } lower { type zeroGradient; } inlet { type fixedValue; value uniform 354690; } outlet { type zeroGradient; } frontAndBack { type zeroGradient; } } I don't know where is wrong and how to solve it, could you tell me something about this?Thanks! Best Regards |
calculatedfvpatchfield |
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse | adona058 | OpenFOAM Bugs | 34 | December 8, 2022 21:27 |
How is the turbulence model called in openfoam? | hz283 | OpenFOAM | 3 | May 4, 2017 21:20 |
terminate called after throwing an instance of 'int' | b614910 | SU2 | 10 | July 27, 2014 22:16 |
understanding how turbulence models are called | romant | OpenFOAM Programming & Development | 0 | March 21, 2012 09:22 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
