Euler solver in BCs
Like Tree3Likes
  • 2 Post By cfdonline2mohsen
  • 1 Post By Hiroshiman
Old   August 7, 2013, 08:35
Default Euler solver in BCs
Hiroshiman is on a distinguished road
I'm trying to implement a boundary conditions that links pressure to outflow using a differential equation (Windkessel) and therefore need to solve it. A simple 1st order backward Euler solver should be enough and, fortunately, one is available in OF.
I've never added a new BC but I tried a take an existing one, use the outflow on the selected patch to calculate the pressure and export it.
I was wondering : what it the best existing BC to start from ? Has anyone an example a the use of a solver in a BC function ?
Best regards,
Florian
Hiroshiman is offline   Reply With Quote
Old   August 8, 2013, 13:19
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Dear Hiroshiman
The following pdf by Håkan Nilsson in Chalmers University is so helpful.
How to implement a new boundary conditions:
http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf
Also, take a look at his homepage for more tutorials:
http://www.tfd.chalmers.se/~hani/index.html
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/
Hiroshiman and ScarFace like this.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
Old   August 8, 2013, 13:37
Hi Kia,
thank you for the links. Actually I've already read the Chalmers guide for the programmation of BCs.
Currently I'm using the codedFixedValue BC with a code that calculates p from phi on the outlet.
I still have a few problems : how can I access the mean value of the pressure on the patch ? I'm able to do it for phi but not for p (surfaceField vs volume Field).
const surfaceScalarField& phi = db().lookupObject<surfaceScalarField>("phi");
const fvsPatchField<scalar>& phip = patch().patchField<surfaceScalarField, scalar>(phi);
I must solve something like :
d(p-phi*R)/dt=f(p,phi) to impose p on the outlet, is it possible to use the ddt solver of openfoam ? I coded an Euler solver but I'd like to use a maximum of integrated functions...
Regards,
Florian
ScarFace likes this.
Old   April 19, 2016, 05:58
United Kingdom
Andreas2014 is on a distinguished road
Hiroshiman, did you manage to get it to work?
Here is how you can access pressure.
const scalarField& press =
                patch().lookupPatchField<volScalarField, scalar>("pressure");
Did you have to solve the ode at every internal iteration in a timestep?
I am using resistance boundary conditions, where the pressure outlet is simply the product of a resistance value and the flowrate at the outlet.
I have coded it with codedFixedValue but am not getting the same results as those I find in Fluent.
Any pointers would be appreciated,
Kind regards,
Andreas
Andreas2014 is offline   Reply With Quote
Old   June 5, 2020, 06:43
Neb
Neb is on a distinguished road
HI, It's been a long time, but has anyone solved this problem? I should be doing the exact same thing.
Thanks!
Neb is offline   Reply With Quote
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) hadikhayyamian ANSYS Meshing & Geometry 5 December 21, 2010 12:28
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
